[postgis-users] postgis libraries not found
Peter N. Schweitzer pschweitzer at usgs.gov
Tue Jan 6 11:17:24 PST 2009
tlange at gwdg.de wrote:
> Fehler = Error: could not load library: »/usr/lib/pgsql/liblwgeom.so«:
> libgeos_c.so.1: cannot open shared object file: File or directory not
> found.
> However, /usr/lib/pgsql/liblwgeom.so exists and libgeos_c.so.1 is in
> /usr/local/lib. Postgis configure script has found the paths for geos and
> proj.
Torsten,
My first guess is that you need to run ldconfig so that the system
will know where to find libgeos_c.so.
You probably know to do createlang plpgsql <dbname> before loading lwpostgis.sql,
but if you had skipped that step, that could cause trouble too.
Peter
Peter N. Schweitzer (MS 954, U.S. Geological Survey, Reston, VA 20192)
(703) 648-6533  FAX: (703) 648-6252  email: pschweitzer at usgs.gov
<http://geology.usgs.gov/peter/>
