[postgis-users] Mixing LINESTRING and MULTILINESTRING data
Ben Madin ben at remoteinformation.com.au
Wed Jan 7 12:39:37 PST 2009
G'day Simon,
Thanks for you help,
On 08/01/2009, at 5:01 AM, postgis-users-
request at postgis.refractions.net wrote:
> Grab the definition of this CHECK constraint by clicking on the
> table in pgAdminIII. Then do this:
> ALTER TABLE gis_roads DROP CONSTRAINT enforce_geotype_the_geom;
> ALTER TABLE gis_roads ADD CONTRAINT enforce_geotype_geom CHECK
> (geometrytype(the_geom) IN
> ('LINESTRING'::text,'MULTILINESTRING'::text) OR gethe_geomom IS NULL);
> It will now allow linestrings and multilinestrings to be inserted
> into the table.
Great - I had some sense the the storage of a geometry type was
slightly more primitive than that.
>> 3. Is there any reason I wouldn't want to mix the two data types...
>> are linestrings more efficiently handled etc.
> I'm not an expert on the specifics of PostGIS but if the object is a
> linestring then store and index it as a linestring and remove the
> additional handling required to extract the linestring from the
> multilinestring for processing and rendering. Has to be a little bit
> faster.
OK - thanks again - it is only a small table by the standards of some
(90000 rows)
cheers
Ben
Ben Madin
REMOTE INFORMATION
t : +61 8 9192 5455
f : +61 8 9192 5535
m : 0448 887 220
Broome   WA   6725
							Out here, it pays to know...
