[postgis-users] ordering spatial data in tables - WARNING! BUG?
Ben Madin ben at remoteinformation.com.au
Wed Jan 7 13:32:48 PST 2009
G'day Vincent,
This didn't work as anticipated - in fact it appears to have truncated
the table!
On 08/01/2009, at 5:01 AM, postgis-users-
request at postgis.refractions.net wrote:
> Another and more <classic> solution (despite slower on big tables) to
> keep spatially close rows together on disk is to use postgresql
> CLUSTER
> statement.
> http://www.postgresql.org/docs/8.3/static/sql-cluster.html
> CLUSTER reorders data on disk using a specified index, therefore
> increasing access speed when reading rows in the index order.
> Example :
> CREATE INDEX idx_mytable_the_geom ON mytable USING GIST(the_geom);
> CLUSTER mytable USING idx_mytable_the_geom;
CLUSTER works on a normal index :
# select count(*) from gis_roads;
  count
  89618
(1 row)
# CLUSTER gis_roads USING gis_roads_gid_key;
CLUSTER
  count
  89618
(1 row)
all good!
But when I try on the gist index
# CLUSTER gis_roads USING gis_roads_gist;
CLUSTER
  count
      0
(1 row)
whoops!
Is this something I missed? Is this a PostgreSQL bug... surely the
cluster command shouldn't be allowed to destroy a whole table.
cheers
Ben
Ben Madin
REMOTE INFORMATION
t : +61 8 9192 5455
f : +61 8 9192 5535
m : 0448 887 220
Broome   WA   6725
							Out here, it pays to know...
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090108/f29872ed/attachment.html>
