[postgis-users] Massive CAD load to Postgis
Gabriel Messner gabmessner at gmail.com
Mon Jan 26 06:07:59 PST 2009
Thanks to all;
The workflow you all mentioned it´s similar to that I´ve imagined. I´ll try
both, load them with ogr2ogr and MFE demo version. I´ll post results in the
list.
see you.
2009/1/23 Chris Hermansen <chris.hermansen at timberline.ca>
> In principle loading 1.000 is the same as loading 1.  As Ivan stated, you
> need to analyze your CAD data to figure out what layers go into which
> tables.
> You can use ogr2ogr to load the data directly.
> You should pick a few files out of your data set to test your ogr2ogr
> conversion (or FME as Ivan stated).  Then you can write a script that loops
> through all your files and converts them.
> Presumably your files are something like map sheets.  Therefore, you would
> want to use the append option of ogr2ogr to, for example, append the roads
> from each cad file into one "roads table".
> CAD files often have weird 'CAD stuff' that doesn't convert well to a GIS -
> think of cartographic as opposed to representational stuff like cells in
> Microstation.
> Have you considered paying a contractor to convert these files?
> Gabriel Messner wrote:
>> I have to load one thousand CAD files to Postgis, but I don´t know how to
>> deal with this issue.
>> Any help will be appreciated....
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> Regards,
> Chris Hermansen         mailto:chris.hermansen at timberline.ca
> tel+1.604.714.2878 · fax+1.604.733.0631 · mob+1.778.232.0644
> Timberline Natural Resource Group · http://www.timberline.ca
> 401 · 958 West 8th Avenue  · Vancouver BC · Canada · V5Z 1E5
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090126/16e954e2/attachment.html>
