[postgis-users] Define spatial reference system for local datum
Sean Fulton
seanasy at gmail.com
Wed Jul 1 17:54:16 PDT 2009
I'm not sure why you want to assign it an SRS of EPSG:4326.
uDig will load and Quantum GIS will happily load and edit the layers if
you assign an SRID of -1.
Sean
On 2009-07-01 16:36:44 -0400, tommy408 <tommytomorow at msn.com> said:
> A lot of these tools that connect to postigs db requires a srid. I was
> trying out Udig. I don't need to use these tools. I can just work with
> shapefile and import it to postgis.
> But what I'm worry about is if I use a defined srid like EPSG:4326 and my
> personal map coordinates will mess up because of the projection. The world
> I'm mapping is flat and endless, it doesn't wrap around like earth map.
> Sean Fulton wrote:
>> Can you just set the SRID to -1. What 'map design tool' are you
>> using?
>> Sean
>> On Jun 30, 3:00 pm, tommy408 <tommytomo... at msn.com> wrote:
>>> I'm not mapping anything on earth. The world I'm doing is flat. The
>>> polygons I'm drawing over is raster image I made. So I'm trying not to
>>> use
>>> any ellipsoid projection.
>>> Suhr, Ralf wrote:
>>>> Do not use a local system. For everything larger than 200meters you
>>> need a
>>>> srs definition, because you can't messure it exactly.
>>>> Take a projection from your living area und shift your geometrys to the
>>>> right place.
>>>> -----Ursprüngliche Nachricht-----
>>>> Von: postgis-users-boun... at postgis.refractions.net
>>>> [mailto:postgis-users-boun... at postgis.refractions.net] Im Auftrag von
>>>> tommy408
>>>> Gesendet: Dienstag, 30. Juni 2009 12:26
>>>> An: postgis-us... at postgis.refractions.net
>>>> Betreff: [postgis-users] Define spatial reference system for local
>>> datum
>>>> I don't need special projection. My map is a flat plane so I'm trying
>>> to
>>>> use local datum as my srs because a bunch of gis map design tool ask
>>> for
>>>> it.
>>>> So I'm trying to add a new srs into postgis spatial_ref_sys table with
>>> the
>>>> following srstext
>>>> LOCAL_CS["Non-Earth (Meter)",LOCAL_DATUM["Local Datum",0],UNIT["Meter",
>>>> 1],AXIS["X",EAST],AXIS["Y",NORTH]]
>>>> What do I put for proj4text?
>>>> View this message in context:
>>>> http://www.nabble.com/Define-spatial-reference-system-for-local-datum...
>>>> Sent from the PostGIS - User mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> postgis-users mailing list postgis-us... at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>> context:http://www.nabble.com/Define-spatial-reference-system-for-local-datum...
Sent
>>> postgis-us... at postgis.refractions.nethttp://postgis.refractions.net/mailman/listinfo/postgis-users
postgis-users
>> mailing list
>> postgis-users at postgis.refractions.net
