[postgis-users] Road Network Graph creation
Daniel Kastl
orkney at gmx.de
Sun Jul 5 18:23:24 PDT 2009
Hi Jaak,
If you need to get the network graph of OSM data you can use osm2pgrouting:
http://pgrouting.postlbs.org/wiki/tools/osm2pgrouting
Currently it doesn't work with large amount of data.
Contributions are always welcome ;-)
Daniel
Jaak Laineste schrieb:
> Hi,
> This function assumes that the road network is already segmented. If
> I have otherwise topologically good network, but without properly
> segmented streets (e.g. like in OSM Shapefiles), then it does not work.
> Best solution would be to have similar extended postgis or pgrouting
> function to do it. Or is there any other good (and free) tool to do it?
> /Jaak
> Re: [postgis-users] Road Network Graph creation
> Daniel Kastl
> Sun, 28 Jun 2009 17:17:33 -0700
> You need to look for the assign_vertex_id function of pgRouting.
> This function creates a network topology.
> Daniel
> Ben Madin schrieb:
> Short Answer - Yes - but of course it depends on the quality of your
> shapefile as to how useful it is.
> Have a look at : http://pgrouting.postlbs.org/
> cheers
> Ben
> On 28/06/2009, at 11:09 PM, Sandeep Kumar Jakkaraju wrote:
> Hello All
> Is there any way I can create a road network graph (nodes,edges) from
> a road shapefile ?
> Thanks
> Regards
> postgis-users mailing list
> /Jaak Laineste
> jaak at nutiteq.com
> www.nutiteq.com
> Phone: +372 777 8800
> Mobile: +372 509 2586
> Skype: nutiteq
