[postgis-users] st_dist, st_sphere, st_spheroid - overhead/efficiency question
Bo Coughlin
bo at rekindl.com
Thu Jul 9 08:46:15 PDT 2009
Have over a million POINT (the_geom) records located in two separate tables
- x.table & y.table. x.table 50,000 records; y.table 995,000 records.
Distances required are all less than 1.5 miles (2414 meters) : all locations
are located within a specific region of the US.
GiST index on the_geom
Goal: distance from all y.the_geom to x.the_geom - (shortest distance). And
then place this distance back into each respective y.table.record
(currently creating temp table to then update y.table)
Current sql:
SELECT m.id AS mid,
m.building_i AS mb_id,
c.id AS cid, c.building_i AS cb_id,
m.streetaddr AS m_address,
m.city AS m_city,
m.state AS m_state,
m.zip AS m_zip,
m.zip4 AS m_zip4,
round(CAST(
ST_Distance_Sphere(
ST_Transform(m.the_geom,4326),
ST_Transform(c.the_geom,4326)
AS numeric
,2) AS dist_meters
FROM market_locations m, customer_locations c
WHERE st_dwithin(ST_Transform(m.the_geom,4326),
ST_Transform(c.the_geom,4326) ,2414.016)
I tried ST_Spheroid as well but after 28 hours I killed it. This current
query (ST_Sphere) has been working for .... 14 hrs. Question is, should
this be expected in terms of overhead and time, are there areas I might be
able to tighten to increase performance on the query (additional btree index
etc.)
System Information: PostgreSQL 8.3.7 on i386-apple-darwin8.11.1, compiled by
GCC i686-apple-darwin8-gcc-4.0.1 (GCC) 4.0.1 (Apple Computer, Inc. build
5370)
Thanks to any and all for assistance.
- bo
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090709/c00d8f80/attachment.html>
