[postgis-users] Postgis - Line to Point distance
Pavel Iacovlev iacovlev.pavel at gmail.com
Fri Jul 10 01:48:25 PDT 2009
you can take the middle of the line, st_line_interpolate_point(the_geom, 0.5)
2009/7/10 Peter Kukuča <pjr.kukuca at gmail.com>:
> Hi Pedro,
> thank you for your reply.
> I cannot use pointn, the line can be up to several hundred kilometers long
> and consits of up to 800 points, so this would be too rough.
> Regardinf the decond suggestion, that is exactly what I am doing now, but I
> don't know, which projection (srid) to transform the wgs84 data into. It
> should work on all of the earth's surface, at least in all of europe for a
> start. And from what I found, the projections are usually tied to a small
> territory. I was thinking about mercator projection, but there is a zillion
> of them in postgis. And I found a post, that the one with srid 900913 is
> working great, but I don't have that one in my postgis.
> 2009/7/10 Pedro Doria Meunier <pdoria at netmadeira.com>
>> -----BEGIN PGP SIGNED MESSAGE-----
>> Hash: SHA1
>> Hi Peter
>> You could use the pointn(geometry, n) for the first point of the
>> linestring as a first approach.
>> As far as meters are concerned here's a little example of transforming
>> the geometry to the desired projected system:
>> select distance(transform(u.coordinates,srid),
>> transform(p.geometry,srid)) AS thedistance
>> HTH,
>> Pedro Doria Meunier
>> GSM: +351 96 17 20 188
>> Skype: pdoriam
>> Peter Kukuča wrote:
>> > Dear sir,
>> > I am not sure if I am writing to the correct email address. I have
>> > found a post on the postgis-users formu from *Rich Gibson *and this
>> > address was next to it.
>> > I am using postgis for a while now and it is great. It solved a lot
>> > of problems for me.
>> > However, I am now facing a problem I cannot solve. I searched for
>> > almost two days now, but I still cannot find an answer. Here is my
>> > problem:
>> > I have a database of linestrings in wgs84 projection and points in
>> > wgs84 projection. I would like to determine the distance between a
>> > line and a point. The ST_distance function does this very well, but
>> > it does not take the wgs84 projection into account and also, the
>> > result is in degrees. On the other hand, the ST_Distance_Spheroid
>> > does take the wgs84 into accound and does give the result in meters,
>> > but it does not accept a linestring as an input parameter.
>> > Is there any way i can the distance between a line and a point in
>> > meters from the wgs84 projected input? I do not need grat accuracy.
>> > +-5 meters is still good enough. Thank you for your tips.
>> > S pozdravom (regards)
>> > Ing. Peter Kukuča
>> > _______________________________________________
>> > postgis-users mailing list
>> > postgis-users at postgis.refractions.net
>> > http://postgis.refractions.net/mailman/listinfo/postgis-users
>> -----BEGIN PGP SIGNATURE-----
>> Version: GnuPG v1.4.7 (GNU/Linux)
>> Comment: Using GnuPG with Fedora - http://enigmail.mozdev.org
>> iD8DBQFKVv052FH5GXCfxAsRAqS1AJ0dfphFX3wrMuo+FdXVRTgmUzHRUACfUmvH
>> 146yGHfxoVmlnt9a91rpWmE=
>> =G70f
>> -----END PGP SIGNATURE-----
> Ing. Peter Kukuča
http://iap.md, The future is open
