[postgis-users] Postgis - Line to Point distance
Pavel Iacovlev
iacovlev.pavel at gmail.com
Fri Jul 10 01:52:31 PDT 2009
And for geometry length use ST_length_spheroid(geometry,spheroid)
On Fri, Jul 10, 2009 at 11:48 AM, Pavel
Iacovlev<iacovlev.pavel at gmail.com> wrote:
> you can take the middle of the line, st_line_interpolate_point(the_geom, 0.5)
> 2009/7/10 Peter Kukuča <pjr.kukuca at gmail.com>:
>> Hi Pedro,
>> thank you for your reply.
>> I cannot use pointn, the line can be up to several hundred kilometers long
>> and consits of up to 800 points, so this would be too rough.
>> Regardinf the decond suggestion, that is exactly what I am doing now, but I
>> don't know, which projection (srid) to transform the wgs84 data into. It
>> should work on all of the earth's surface, at least in all of europe for a
>> start. And from what I found, the projections are usually tied to a small
>> territory. I was thinking about mercator projection, but there is a zillion
>> of them in postgis. And I found a post, that the one with srid 900913 is
>> working great, but I don't have that one in my postgis.
>> 2009/7/10 Pedro Doria Meunier <pdoria at netmadeira.com>
>>> -----BEGIN PGP SIGNED MESSAGE-----
>>> Hash: SHA1
>>> Hi Peter
>>> You could use the pointn(geometry, n) for the first point of the
>>> linestring as a first approach.
>>> As far as meters are concerned here's a little example of transforming
>>> the geometry to the desired projected system:
>>> select distance(transform(u.coordinates,srid),
>>> transform(p.geometry,srid)) AS thedistance
>>> HTH,
>>> Pedro Doria Meunier
>>> GSM: +351 96 17 20 188
>>> Skype: pdoriam
>>> Peter Kukuča wrote:
>>> > Dear sir,
>>> > I am not sure if I am writing to the correct email address. I have
>>> > found a post on the postgis-users formu from *Rich Gibson *and this
>>> > address was next to it.
>>> > I am using postgis for a while now and it is great. It solved a lot
>>> > of problems for me.
>>> > However, I am now facing a problem I cannot solve. I searched for
>>> > almost two days now, but I still cannot find an answer. Here is my
>>> > problem:
>>> > I have a database of linestrings in wgs84 projection and points in
>>> > wgs84 projection. I would like to determine the distance between a
>>> > line and a point. The ST_distance function does this very well, but
>>> > it does not take the wgs84 projection into account and also, the
>>> > result is in degrees. On the other hand, the ST_Distance_Spheroid
>>> > does take the wgs84 into accound and does give the result in meters,
>>> > but it does not accept a linestring as an input parameter.
>>> > Is there any way i can the distance between a line and a point in
>>> > meters from the wgs84 projected input? I do not need grat accuracy.
>>> > +-5 meters is still good enough. Thank you for your tips.
>>> > S pozdravom (regards)
>>> > Ing. Peter Kukuča
>>> > _______________________________________________
>>> > postgis-users mailing list
>>> > postgis-users at postgis.refractions.net
>>> > http://postgis.refractions.net/mailman/listinfo/postgis-users
>>> -----BEGIN PGP SIGNATURE-----
>>> Version: GnuPG v1.4.7 (GNU/Linux)
>>> Comment: Using GnuPG with Fedora - http://enigmail.mozdev.org
>>> iD8DBQFKVv052FH5GXCfxAsRAqS1AJ0dfphFX3wrMuo+FdXVRTgmUzHRUACfUmvH
>>> 146yGHfxoVmlnt9a91rpWmE=
>>> =G70f
>>> -----END PGP SIGNATURE-----
>> Ing. Peter Kukuča
> http://iap.md, The future is open
