[postgis-users] Postgis - Line to Point distance
Peter Kukuča pjr.kukuca at gmail.com
Fri Jul 10 01:53:47 PDT 2009
ST_Length_spheroid is perfectly great, but it does not take a line as an
input :-(
2009/7/10 Pavel Iacovlev <iacovlev.pavel at gmail.com>
> And for geometry length use ST_length_spheroid(geometry,spheroid)
> On Fri, Jul 10, 2009 at 11:48 AM, Pavel
> Iacovlev<iacovlev.pavel at gmail.com> wrote:
> > you can take the middle of the line, st_line_interpolate_point(the_geom,
> 0.5)
> > 2009/7/10 Peter Kukuča <pjr.kukuca at gmail.com>:
> >> Hi Pedro,
> >> thank you for your reply.
> >> I cannot use pointn, the line can be up to several hundred kilometers
> long
> >> and consits of up to 800 points, so this would be too rough.
> >> Regardinf the decond suggestion, that is exactly what I am doing now,
> but I
> >> don't know, which projection (srid) to transform the wgs84 data into. It
> >> should work on all of the earth's surface, at least in all of europe for
> a
> >> start. And from what I found, the projections are usually tied to a
> small
> >> territory. I was thinking about mercator projection, but there is a
> zillion
> >> of them in postgis. And I found a post, that the one with srid 900913 is
> >> working great, but I don't have that one in my postgis.
> >> 2009/7/10 Pedro Doria Meunier <pdoria at netmadeira.com>
> >>> -----BEGIN PGP SIGNED MESSAGE-----
> >>> Hash: SHA1
> >>> Hi Peter
> >>> You could use the pointn(geometry, n) for the first point of the
> >>> linestring as a first approach.
> >>> As far as meters are concerned here's a little example of transforming
> >>> the geometry to the desired projected system:
> >>> select distance(transform(u.coordinates,srid),
> >>> transform(p.geometry,srid)) AS thedistance
> >>> HTH,
> >>> Pedro Doria Meunier
> >>> GSM: +351 96 17 20 188
> >>> Skype: pdoriam
> >>> Peter Kukuča wrote:
> >>> > Dear sir,
> >>> > I am not sure if I am writing to the correct email address. I have
> >>> > found a post on the postgis-users formu from *Rich Gibson *and this
> >>> > address was next to it.
> >>> > I am using postgis for a while now and it is great. It solved a lot
> >>> > of problems for me.
> >>> > However, I am now facing a problem I cannot solve. I searched for
> >>> > almost two days now, but I still cannot find an answer. Here is my
> >>> > problem:
> >>> > I have a database of linestrings in wgs84 projection and points in
> >>> > wgs84 projection. I would like to determine the distance between a
> >>> > line and a point. The ST_distance function does this very well, but
> >>> > it does not take the wgs84 projection into account and also, the
> >>> > result is in degrees. On the other hand, the ST_Distance_Spheroid
> >>> > does take the wgs84 into accound and does give the result in meters,
> >>> > but it does not accept a linestring as an input parameter.
> >>> > Is there any way i can the distance between a line and a point in
> >>> > meters from the wgs84 projected input? I do not need grat accuracy.
> >>> > +-5 meters is still good enough. Thank you for your tips.
> >>> > S pozdravom (regards)
> >>> > Ing. Peter Kukuča
> >>> > _______________________________________________
> >>> > postgis-users mailing list
> >>> > postgis-users at postgis.refractions.net
> >>> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> >>> -----BEGIN PGP SIGNATURE-----
> >>> Version: GnuPG v1.4.7 (GNU/Linux)
> >>> Comment: Using GnuPG with Fedora - http://enigmail.mozdev.org
> >>> iD8DBQFKVv052FH5GXCfxAsRAqS1AJ0dfphFX3wrMuo+FdXVRTgmUzHRUACfUmvH
> >>> 146yGHfxoVmlnt9a91rpWmE=
> >>> =G70f
> >>> -----END PGP SIGNATURE-----
> >> Ing. Peter Kukuča
> > http://iap.md, The future is open
Ing. Peter Kukuča
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090710/db6ae1eb/attachment.html>
