[postgis-users] KML Export
Kevin Neufeld
kneufeld at refractions.net
Tue Jul 14 08:50:02 PDT 2009
As you've seen, there is the ST_AsKML command (http://postgis.refractions.net/documentation/manual-svn/ST_AsKML.html)
that will convert a single geometry to KML.
All you need to do is add some xml tags before the export geometry tag and again after, closing the document.
Here's an example of a simple wrapper that does this inside the database, though you'd probably want to do this in PHP:
http://lists.refractions.net/pipermail/postgis-users/attachments/20070914/7a02d424/askml.sql
Example use case:
SELECT askml('my_title', 'description', collect(the_geom))
FROM my_spatial_table
WHERE ....
yields something like:
<?xml version='1.0' encoding='UTF-8'?>
<kml xmlns='http://earth.google.com/kml/2.1'>
<Document>
<name>'my_title'</name>
<description>'description'</description>
<Style id='defaultStyle'>
<LineStyle>
<color>ff00ff00</color>
<width>1</width>
</LineStyle>
<PolyStyle>
<color>5f00ff00</color>
</PolyStyle>
</Style>
<Placemark>
<styleUrl>#defaultStyle</styleUrl>
<MultiGeometry>
<Point>
<coordinates>-122.319,47.164</coordinates>
</Point>
<Point>
<coordinates>-122.272,47.067</coordinates>
</Point>
</MultiGeometry>
</Placemark>
</Document>
</kml>
Cheers,
Kevin
Stefan Schwarzer wrote:
> Hi there,
> I made a tour on Google to look around if there exist some KML export
> tool. I've seen the Set_AsKML command; I've seen this
> <http://postgis.refractions.net/pipermail/postgis-users/2007-September/017070.html> dicussion;
> and have found that someone wrote a script
> <http://postgis3d.blogspot.com/2007/12/googleearth-export.html> for
> postgis; and a phyton script
> <http://dev.riverchange.org/google_earth/genshi_template.kml>.
> But it seems that there is no easy-way-to-go export/wrapper script,
> enabling for example the execution of pgsql2kml...
> Or can someone give be a hint how to develop a KML export for a PHP
> based Data Portal?
> Thanks for any help,
> Stef
> postgis-users mailing list
