[postgis-users] KML Export
Stefan Schwarzer stefan.schwarzer at grid.unep.ch
Wed Jul 15 00:44:47 PDT 2009
Ah, thanks a lot! That sounds great!
However, when inserting the function and executing this:
	SELECT askml('my_title', 'description', collect(the_geom)) FROM
(SELECT c.the_geom FROM countries_view AS c) AS foo
I get this error:
	ERROR:  geometry_to_kml: 'GeometryCollection' geometry type not
supported by Google Earth
	CONTEXT:  SQL function "askml" statement 1
	PL/pgSQL function "askml" line 21 at assignment
If I understand it correctly from this conversation, I'd need the
latest version of Postgis to solve that issue, right?
Thanks for your valuable help,
Stefan
On Jul 14, 2009, at 5:50 PM, Kevin Neufeld wrote:
> As you've seen, there is the ST_AsKML command (http://postgis.refractions.net/documentation/manual-svn/ST_AsKML.html
> ) that will convert a single geometry to KML.
> All you need to do is add some xml tags before the export geometry
> tag and again after, closing the document.
> Here's an example of a simple wrapper that does this inside the
> database, though you'd probably want to do this in PHP:
> http://lists.refractions.net/pipermail/postgis-users/attachments/20070914/7a02d424/askml.sql
> Example use case:
> FROM my_spatial_table
> WHERE ....
> yields something like:
> <?xml version='1.0' encoding='UTF-8'?>
> <kml xmlns='http://earth.google.com/kml/2.1'>
> <Document>
> <name>'my_title'</name>
> <description>'description'</description>
> <Style id='defaultStyle'>
>  <LineStyle>
>    <color>ff00ff00</color>
>    <width>1</width>
>  </LineStyle>
>  <PolyStyle>
>    <color>5f00ff00</color>
>  </PolyStyle>
> </Style>
> <Placemark>
>  <styleUrl>#defaultStyle</styleUrl>
>  <MultiGeometry>
>    <Point>
>      <coordinates>-122.319,47.164</coordinates>
>    </Point>
>    <Point>
>      <coordinates>-122.272,47.067</coordinates>
>    </Point>
>  </MultiGeometry>
> </Placemark>
> </Document>
> </kml>
> Cheers,
> Kevin
> Stefan Schwarzer wrote:
>> Hi there,
>> I made a tour on Google to look around if there exist some KML
>> export tool. I've seen the Set_AsKML command; I've seen this <http://postgis.refractions.net/pipermail/postgis-users/2007-September/017070.html
>> > dicussion; and have found that someone wrote a script <http://postgis3d.blogspot.com/2007/12/googleearth-export.html
>> > for postgis; and a phyton script <http://dev.riverchange.org/google_earth/genshi_template.kml
>> >. But it seems that there is no easy-way-to-go export/wrapper
>> script, enabling for example the execution of pgsql2kml...
>> Or can someone give be a hint how to develop a KML export for a PHP
>> based Data Portal?
>> Thanks for any help,
>> Stef
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090715/ad702d13/attachment.html>
