[postgis-users] spheroid bounding box calculation
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Jul 23 12:59:09 PDT 2009
steve enzer wrote:
> I'm facing a similar issue; a huge postgis database with a point
> column, trying to find a clean query to bring back the nearest n
> results to a point. Why isn't that easy? Or is it?
The problem is that the nearest n points is not well defined in spatial
terms. For example think about the difference between rural Wyoming and
downtown Manhattan!
Typically to make a query fast you need to use and index and that means
you need a bounding box that specifies your search distance. But the
bbox that is good for Manhattan may be too small for Wyoming.
One strategy is to search at a given small radius and see if you have
enough results, if not double the search radius and redo the query.
While this may seem costly, it is in fact very fast because postgresql
is very good at caching results and pages in memory.
Hope this helps,
-Steve
> I'm using georuby and spatial adapter.
> Steve
> On Thu, Jul 23, 2009 at 10:01 AM, Jeff Davis<pgsql at j-davis.com> wrote:
>> On Thu, 2009-07-23 at 08:58 -0700, Paul Ramsey wrote:
>>> Hopefully GEOGRAPHY will retire all these requirements once and for
>>> all :)
>> Is that something under development? I'm new to these lists, so I
>> haven't been following.
>> Regards,
>> Jeff Davis
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
