[postgis-users] spheroid bounding box calculation
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Jul 23 13:17:28 PDT 2009
Oh, and the basic sql query would be:
select * from poi_table where st_within(setsrid(makepoint(x,y),4326),
the_geom, radius) order by st_distance(setsrid( makepoint(x,y),4326),
the_geom) asc limit n;
(x,y) == (lon, lat)
radius == is your initial search radius
n == is your limit on results
-Steve
Stephen Woodbridge wrote:
> steve enzer wrote:
>> I'm facing a similar issue; a huge postgis database with a point
>> column, trying to find a clean query to bring back the nearest n
>> results to a point. Why isn't that easy? Or is it?
> The problem is that the nearest n points is not well defined in spatial
> terms. For example think about the difference between rural Wyoming and
> downtown Manhattan!
> Typically to make a query fast you need to use and index and that means
> you need a bounding box that specifies your search distance. But the
> bbox that is good for Manhattan may be too small for Wyoming.
> One strategy is to search at a given small radius and see if you have
> enough results, if not double the search radius and redo the query.
> While this may seem costly, it is in fact very fast because postgresql
> is very good at caching results and pages in memory.
> Hope this helps,
> -Steve
>> I'm using georuby and spatial adapter.
>> Steve
>> On Thu, Jul 23, 2009 at 10:01 AM, Jeff Davis<pgsql at j-davis.com> wrote:
>>> On Thu, 2009-07-23 at 08:58 -0700, Paul Ramsey wrote:
>>>> Hopefully GEOGRAPHY will retire all these requirements once and for
>>>> all :)
>>> Is that something under development? I'm new to these lists, so I
>>> haven't been following.
>>> Regards,
>>> Jeff Davis
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
