[postgis-users] spheroid bounding box calculation
Paul Ramsey
pramsey at cleverelephant.ca
Thu Jul 23 13:08:33 PDT 2009
Nearest neighbor, as Stephen notes in the followup is not something
that is necessarily easy in general. However! Another development
on-stream for PostgreSQL 8.5 will allow us to both (a) use k-d tree
indexes for points, which are much more efficient and (b) to do
nearest-neighbor searching using the index tree, which will be a great
deal more optimal for general cases.
However, those changes are a good 9 months out (we need new PgSQL
release *and* new PostGIS release to leverage it). In the meanwhile,
an iterative box that doubles until it finds something is your best
bet. There should be examples in the wiki, it's not an uncommon
question.
P
On Thu, Jul 23, 2009 at 11:19 AM, steve enzer<steve.enzer at gmail.com> wrote:
> I'm facing a similar issue; a huge postgis database with a point
> column, trying to find a clean query to bring back the nearest n
> results to a point. Why isn't that easy? Or is it?
> I'm using georuby and spatial adapter.
> Steve
> On Thu, Jul 23, 2009 at 10:01 AM, Jeff Davis<pgsql at j-davis.com> wrote:
>> On Thu, 2009-07-23 at 08:58 -0700, Paul Ramsey wrote:
>>> Hopefully GEOGRAPHY will retire all these requirements once and for
>>> all :)
>> Is that something under development? I'm new to these lists, so I
>> haven't been following.
>> Regards,
>> Jeff Davis
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
