[postgis-users] google -> wgs conversion (failed to load NAD27-83 correction file)
Jaak Laineste
jaak at nutiteq.com
Fri Jul 24 07:52:33 PDT 2009
I seem to have blind spot somewhere. I can convert wgs->google coordinate
system fine:
select astext(transform(geomfromtext('POINT(-22.19921875 1.47265625)',4326),
900913));
-> "POINT(-2471205.72725849 163953.396913543)"
But when try to convert it back:
select st_asewkt(transform(geomfromtext('POINT(-2471205.72725849
163953.396913543)',900913), 4326));
then I get absurd numbers:
-> "SRID=4326;POINT(-3.48051770446448e-06 2.30891282668362e-07)"
And there is also message: WARNING: transform: -38 (failed to load NAD27-83
correction file)
In other machine (windows btw) same query works fine.
After restart of the database (postgis which is debian) it worked exactly
one time. See 2 identical queries in a row:
gis=# select st_asewkt(st_transform(geomfromtext('POINT(-2471205.72725849
st_asewkt
SRID=4326;POINT(-22.19921875 1.47265624999999)
(1 row)
WARNING: transform: -38 (failed to load NAD27-83 correction file)
st_asewkt
(1 row)
Reinstalling postgis packages, including proj did not help. I have postgres
8.3 with 1.3.3-3 (from postgresql-8.3-postgis debian package). I triad also
with 1.3.5 postgis which was latest debian package what I found, same thing
Also I do not get what all this has to do with "NAD27-83 correction"
/Jaak Laineste
jaak at nutiteq.com
Skype: nutiteq
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090724/d59aec08/attachment.html>
