[postgis-users] google -> wgs conversion (failed to load NAD27-83 correction file)
Robert Coup
robert.coup at onetrackmind.co.nz
Fri Jul 24 17:00:53 PDT 2009
Hi Jaak,
900913 uses the "null" gridshift to convert ellipsoids (WGS84 <> Sphere)
without doing proper calculations (ie. just plain ignoring that WGS84 isn't
a sphere).
Where did your proj build come from? There was a problem with the
Debian/Ubuntu packaging a while back where the grid-shift files were marked
as being applicable to both 32 & 64 bit, when they're not. So if you weren't
on the architecture which it was built on, weird gridshift-errors would come
about.
http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=530818
Rob :)
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090725/06a2b9cc/attachment.html>
