[postgis-users] st_within maddness
Paul Ramsey
pramsey at cleverelephant.ca
Fri Jul 24 08:10:06 PDT 2009
Works as of PostGIS 1.4 too (result returns). So at this point you are
either (a) upgrading (to 1.3.6 at least, since Maxime showed that
worked) or (b) searching for a workaround so you don't have to
upgrade. Do you need (b)?
P.
On Fri, Jul 24, 2009 at 7:57 AM, Kevin Galligan<kg at kagii.com> wrote:
> I tried with a different SRID anyway, just to remove that from the mix...
> create table rresp.testwithin4326(id int);
> SELECT AddGeometryColumn ('rresp','testwithin4326','bbox',4326,'POLYGON',2);
> insert into rresp.testwithin4326(id, bbox) values(1,
> ST_SetSRID(ST_MakeBox2D(ST_Point(-71.0600, 42.3600),ST_Point(-71.0000,
> 42.4200)),4326));
> select asewkt(ST_Buffer(ST_SetSRID(ST_MakePoint(-71.0600, 42.3600),4326), .5));
> --Just to make sure we have a row (we do)
> select asewkt(bbox) from rresp.testwithin4326;
> --Select from the circle (it returns nothing)
> select asewkt(bbox) from rresp.testwithin4326 where st_within(bbox,
> --Select with a bigger box (returns the row)
> ST_SetSRID(ST_MakeBox2D(ST_Point(-71.1600, 42.2600),ST_Point(-70.0900,
> 42.5200)),4326));
> On Fri, Jul 24, 2009 at 10:47 AM, Maxime van Noppen<maxime at altribe.org> wrote:
>> On 07/24/09 16:46, Kevin Galligan wrote:
>>> Might I ask where you get the definition of srid '900913'? I know I
>>> had to insert that myself from something I found on the web. I'm
>>> shooting in the dark here, but that's another possible variable in the
>>> mix.
>> I didn't check the SRID value but PostGIS said nothing about it :
>>> tmp=# create table testwithin(id int);
>>> CREATE TABLE
>>> tmp=# SELECT AddGeometryColumn('testwithin','bbox',900913,'POLYGON',2);
>>> addgeometrycolumn
>>> public.testwithin.bbox SRID:900913 TYPE:POLYGON DIMS:2
>>> (1 row)
>>> tmp=# insert into testwithin(id, bbox) values(1, ST_SetSRID(ST_MakeBox2D(ST_Point(-8232000, 4980000),ST_Point(-8231900,
>>> 4980100)),900913));
>>> INSERT 0 1
>>> tmp=# select asewkt(bbox) from testwithin where st_within(bbox, ST_Buffer(ST_SetSRID(ST_MakePoint(-8232000, 4980000),900913), 500));
>>> asewkt
>>> SRID=900913;POLYGON((-8232000 4980000,-8232000 4980100,-8231900 4980100,-8231900 4980000,-8232000 4980000))
>>> (1 row)
>> AFAIK it's a vanilla PostGIS-1.3.6.
>> yabo
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> Kevin Galligan
> www.kagii.com
