[postgis-users] st_within maddness
Kevin Galligan
kg at kagii.com
Fri Jul 24 09:49:59 PDT 2009
A workaround would be OK, but I'm thinking 1.3.6 is a good way to go.
Not sure the best approach on that. Running on Ubuntu. Postgis
installed with the standard apt package installer. I plan on just
building, but I'm sure there will be all sorts of path and dependency
issues. Hmm.
On Fri, Jul 24, 2009 at 11:10 AM, Paul Ramsey<pramsey at cleverelephant.ca> wrote:
> Works as of PostGIS 1.4 too (result returns). So at this point you are
> either (a) upgrading (to 1.3.6 at least, since Maxime showed that
> worked) or (b) searching for a workaround so you don't have to
> upgrade. Do you need (b)?
> P.
> On Fri, Jul 24, 2009 at 7:57 AM, Kevin Galligan<kg at kagii.com> wrote:
>> I tried with a different SRID anyway, just to remove that from the mix...
>> create table rresp.testwithin4326(id int);
>> SELECT AddGeometryColumn ('rresp','testwithin4326','bbox',4326,'POLYGON',2);
>> insert into rresp.testwithin4326(id, bbox) values(1,
>> ST_SetSRID(ST_MakeBox2D(ST_Point(-71.0600, 42.3600),ST_Point(-71.0000,
>> 42.4200)),4326));
>> select asewkt(ST_Buffer(ST_SetSRID(ST_MakePoint(-71.0600, 42.3600),4326), .5));
>> --Just to make sure we have a row (we do)
>> select asewkt(bbox) from rresp.testwithin4326;
>> --Select from the circle (it returns nothing)
>> select asewkt(bbox) from rresp.testwithin4326 where st_within(bbox,
>> --Select with a bigger box (returns the row)
>> ST_SetSRID(ST_MakeBox2D(ST_Point(-71.1600, 42.2600),ST_Point(-70.0900,
>> 42.5200)),4326));
>> On Fri, Jul 24, 2009 at 10:47 AM, Maxime van Noppen<maxime at altribe.org> wrote:
>>> On 07/24/09 16:46, Kevin Galligan wrote:
>>>> Might I ask where you get the definition of srid '900913'? I know I
>>>> had to insert that myself from something I found on the web. I'm
>>>> shooting in the dark here, but that's another possible variable in the
>>>> mix.
>>> I didn't check the SRID value but PostGIS said nothing about it :
>>>> tmp=# create table testwithin(id int);
>>>> CREATE TABLE
>>>> tmp=# SELECT AddGeometryColumn('testwithin','bbox',900913,'POLYGON',2);
>>>> addgeometrycolumn
>>>> public.testwithin.bbox SRID:900913 TYPE:POLYGON DIMS:2
>>>> (1 row)
>>>> tmp=# insert into testwithin(id, bbox) values(1, ST_SetSRID(ST_MakeBox2D(ST_Point(-8232000, 4980000),ST_Point(-8231900,
>>>> 4980100)),900913));
>>>> INSERT 0 1
>>>> tmp=# select asewkt(bbox) from testwithin where st_within(bbox, ST_Buffer(ST_SetSRID(ST_MakePoint(-8232000, 4980000),900913), 500));
>>>> asewkt
>>>> SRID=900913;POLYGON((-8232000 4980000,-8232000 4980100,-8231900 4980100,-8231900 4980000,-8232000 4980000))
>>>> (1 row)
>>> AFAIK it's a vanilla PostGIS-1.3.6.
>>> yabo
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> Kevin Galligan
>> www.kagii.com
Kevin Galligan
www.kagii.com
