[postgis-users] postgis1.4.0 installation errors on pgsql8.4.. Solution
Ravi
ravivundavalli at yahoo.com
Tue Jul 28 13:58:52 PDT 2009
I succeeded in installing postgis1.4.0 on pgsql8.4.
The readme.txt for postgis1.4.0 installation on pgsql8.4 may be modified
if possible as follows.
Steps to be changed are shown below.
1) Copy the contents of this folder into C:\Program
Files\PostgreSQL\8.4 or where you have installed
This step may be
1)Copy the contents of this folder postgis1.4.0 C:\Program
Files\PostgreSQL\8.4 , Bin contents--> C:\Program
Files\PostgreSQL\8.4\Bin, Lib contents --> to C:\Program
Files\PostgreSQL\8.4\Lib
The folder postgis1.4.0 may be copied to C:\Program
Files\PostgreSQL\8.4.
4) "C:\Program Files\PostgreSQL\8.4\bin\psql" -p 5432
-U postgres -d template_postgis14 -f "C:\Program
Files\PostgreSQL\8.4\share\contrib\postgis\postgis.sql"
Change the above path as the new folder postgis1.4.0 just copied
has a path C:\Program Files\PostgreSQL\8.4\postgis1.4.0
This step may be
Files\PostgreSQL\8.4\postgis1.4.0\postgis\postgis.sql"
Ravi Kumar
Looking for local information? Find it on Yahoo! Local http://in.local.yahoo.com/
