[postgis-users] Issue with BOX3D and distance
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Wed Jul 29 05:50:15 PDT 2009
Mulone wrote:
> I'm trying to get all the geometries within a certain radius from a point.
> Given that distance doesn't use the index, I added the && BBox operator to
> narrow down the problem to a smaller dataset, but the problem is that the
> radius is expressed in meters and the BBOX in degrees, but I'd like to
> define them in a consistent way. Besides, working on a very small dataset
> (about 2000 geometries), I was shocked to see that it takes up to 500ms to
> perform the query... That's why I started messing with the index.
> Mulone
Okay, this is a fairly standard scenario. What normally happens in a
query similar to yours is that the && operator pulls matches directly
from the index, the results of which are then run through the distance()
function. (Incidentally, I notice you are still using the non ST_ prefix
functions in your queries - you probably want to change this given that
these are deprecated)
So I suspect a large amount of it comes down to how do you calculate
your BOX3D here:
way && setsrid(box3d('BOX3D(-6.216 53.300,-6.220 53.304)'), 4326)
If you can reduce the size of the BOX3D so that it exactly matches your
area of interest, then that should give you the best overall performance.
HTH,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
