[postgis-users] isnumeric function
Alexandre Dube
adube at mapgears.com
Wed Jun 10 12:29:37 PDT 2009
Hi Paul,
Sorry for being a bit clueless. I'm trying to create the function
while in command line but it's not working. I tried while connected
(using psql and the SQL statement only) and it worked, but I need to do
it in command line (inside a script).
Here's what I tried and didn't work :
psql -d mydb -c "CREATE FUNCTION isnumeric(text) RETURNS boolean AS
'SELECT $1 ~ ''^[0-9]+$'' ' LANGUAGE 'sql'"
=== error message ===
ERROR: operator is not unique: ~ unknown
LINE 1: ...CTION isnumeric(text) RETURNS boolean AS 'SELECT ~ ''^[0-9]...
HINT: Could not choose a best candidate operator. You might need to add
explicit type casts.
Any more clue ?
Alexandre
Paul Ramsey wrote:
> As your link suggests, Alexandre, there is no such function, but it
> can be done w/ a regex pattern, which postgresql supports.
> pramsey=# CREATE FUNCTION isnumeric(text) RETURNS boolean AS 'SELECT
> $1 ~ ''^[0-9]+$'' ' LANGUAGE 'sql';
> pramsey=# select isnumeric('this');
> isnumeric
> f
> (1 row)
> pramsey=# select isnumeric('34');
> isnumeric
> t
> (1 row)
Alexandre Dubé
Mapgears
www.mapgears.com
