[postgis-users] isnumeric function
Paul Ramsey
pramsey at cleverelephant.ca
Wed Jun 10 16:52:50 PDT 2009
See how the $1 is missing in your error message? The shell is eating
that. Try escaping the $ characters with a \ in your shell call.
On Wed, Jun 10, 2009 at 12:29 PM, Alexandre Dube<adube at mapgears.com> wrote:
> Hi Paul,
> Sorry for being a bit clueless. I'm trying to create the function while in
> command line but it's not working. I tried while connected (using psql and
> the SQL statement only) and it worked, but I need to do it in command line
> (inside a script).
> Here's what I tried and didn't work :
> psql -d mydb -c "CREATE FUNCTION isnumeric(text) RETURNS boolean AS 'SELECT
> $1 ~ ''^[0-9]+$'' ' LANGUAGE 'sql'"
> === error message ===
> ERROR: operator is not unique: ~ unknown
> LINE 1: ...CTION isnumeric(text) RETURNS boolean AS 'SELECT ~ ''^[0-9]...
> HINT: Could not choose a best candidate operator. You might need to add
> explicit type casts.
> Any more clue ?
> Alexandre
> Paul Ramsey wrote:
>> As your link suggests, Alexandre, there is no such function, but it
>> can be done w/ a regex pattern, which postgresql supports.
>> pramsey=# CREATE FUNCTION isnumeric(text) RETURNS boolean AS 'SELECT
>> $1 ~ ''^[0-9]+$'' ' LANGUAGE 'sql';
>> pramsey=# select isnumeric('this');
>> isnumeric
>> f
>> (1 row)
>> pramsey=# select isnumeric('34');
>> isnumeric
>> t
>> (1 row)
> Alexandre Dubé
> Mapgears
> www.mapgears.com
> postgis-users mailing list
