[postgis-users] Postgis witjh postgresql 8.1.11
Paragon Corporation
lr at pcorp.us
Fri Jun 12 13:13:15 PDT 2009
Well you should be using PostGIS 1.3.6 but I don't recall any issue with
postgresql 8.1.11 and PostGIS 1.3.1. then again its been a while since I
used 8.1
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Brian
Modra
Sent: Friday, June 12, 2009 1:30 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Postgis witjh postgresql 8.1.11
Hi
does anyone know of any problems with postgis in postgresql 8.1.11 ?
I'm using postgis 1.3.1 in postgresql 8.1.11
uname says:
Linux lead 2.6.24-gentoo-r4 #1 SMP Sat Apr 5 18:42:58 SAST 2008 i686
Intel(R) Xeon(TM) CPU 3.40GHz GenuineIntel GNU/Linux
The reason I ask is that Gentoo's package management system (portage) wanted
to downgrade postgres to 8.0.15...
I assume this is because postgis was tested by the gentoo maintainers on
postgres 8.0.15 only, but I'm a bit concerned that there may be some problem
they spotted in the 8.1 database.
Can anyone confirm that postgis 1.3.1 is actually totally stable in
postgresql 8.1.11 ?
Thanks
Brian
Brian Modra Land line: +27 23 5411 462
Mobile: +27 79 69 77 082
5 Jan Louw Str, Prince Albert, 6930
Postal: P.O. Box 2, Prince Albert 6930
South Africa
http://www.zwartberg.com/
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
