[postgis-users] GEOMETRIES with different SRIDs
africa4you a4uofbiz at yahoo.com
Sun Jun 14 09:20:01 PDT 2009
Hi
I have two points in different SRID's and would like to calculate the
distance between them, unfortunately this type of operation doesnt seem to
be valid (Operation on two GEOMETRIES with different SRIDs ). Any help in
solving this issue would be appreciated. Please see the sql below:
Kind regards
Grant Edwards
SELECT postgis_full_version()
"POSTGIS="1.3.3" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.6.0, 21 Dec 2007"
USE_STATS"
SELECT utmzone(ST_Centroid(setsrid((makepoint(28.060455,
-26.056947)),4326))); //Johannesburg (utmzone = 32735)
EPSG Projection 32735 - WGS 84 / UTM zone 35S
http://spatialreference.org/ref/epsg/32735/
SELECT utmzone(ST_Centroid(setsrid((makepoint(18.3793284,
-33.9228922)),4326))); //Cape Town (utmzone = 32734)
EPSG Projection 32734 - WGS 84 / UTM zone 34S
http://spatialreference.org/ref/epsg/32734/
SELECT  ST_Distance(ST_Transform(setsrid((makepoint(28.060455,
-26.056947)),4326),utmzone(ST_Centroid(setsrid((makepoint(28.060455,
-26.056947)),4326)))) ,
                    ST_Transform(setsrid((makepoint(18.3793284,
-33.9228922)),4326),utmzone(ST_Centroid(setsrid((makepoint(18.3793284,
-33.9228922)),4326)))))  as dist_meters
ERROR:  Operation on two GEOMETRIES with different SRIDs
View this message in context: http://www.nabble.com/GEOMETRIES-with-different-SRIDs-tp24022339p24022339.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
