[postgis-users] Generating areas from point datasets with PostGIS
nicklas.aven at jordogskog.no
Fri Jun 19 00:22:55 PDT 2009
I am not sure I understand what you want to do. Do you want one sqare-polygon for each point?
Now you are unioning them all together to one big polygon....
anyway
instead of :
envelope(buffer(geom,1.0/230.0))
I guess it's more effective to use:
st_expand(geom, 1.0/230.0)
http://www.postgis.org/documentation/manual-svn/ST_Expand.html
/Nicklas
2009-06-19 pcreso at pcreso.com wrote:
>Hi,
>Any comments or advice appreciated...
>I have a table (155m points) of circumpolar depth points.
>From this I want to use POstGIS to generate polygons based on depths.
>There are about 700,000 points in the Ross Sea region, each has a depth (or altitude) associated with it. The points are 1/2nm apart (GEBCO 2008 data)
>I figure the following approach will work to generate reasonable polygons for areas in the Ross Sea shallower than 550m:
>select astext(geomunion(envelope(buffer(geom,1.0/230.0))))
> from srtm_ant
> where depth <0
> and depth >-500
> and geom && setsrid(geometryfromtext('POLYGON((155 -80,155 -60,200 -60,200 -80,155 -80))'),4326);
>The && WKT coords define the Ross Sea region, 1/2nm is 1/120 degree so a buffer of 1/230 degree should ensure the envelopes of the buffered points all overlap.
>Does anyone have any suggestions/advice regarding this?
>Better or faster approaches, etc.
>Thanks,
> Brent Wood
>_______________________________________________
>postgis-users mailing list
>postgis-users at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090619/1660227c/attachment.html>
