[postgis-users] build a polygon from points
nicklas.aven at jordogskog.no nicklas.aven at jordogskog.no
Tue Jun 23 00:43:29 PDT 2009
ok you saw my second answer?st_makeline should work if you just define an apoint array likearray[point1, point2,point2, point1] /Nicklas
2009-06-23 Caspa wrote:
yeah this could be the solution...unfortunately I have postgis version 1.3.5 and i doesn't have this feature yet..(I'm on debian system and don't want to build from source)
>>SELECT ST_MakePoly(ST_>
>LineFromMultiPoint(ST_collect(coord1, coord2, coord3, coord4, coord5, coord1 ))) from table
>this doesn't work, but I'm trying to use LineFromMultiPoint in other ways...maybe it works...
>THANKS
2009/6/23 <nicklas.aven at jordogskog.no>
>About st_makeline an array is needed like this example:>select st_makepolygon(ST_MakeLine(array[st_point(3, 2),st_point(2, 2),st_point(3, 3),st_point(2, 5),st_point(5, 5),st_point(3, 2)]));> >greetings >Nicklas>
> Hi, thanks for that,
> >those are colunm in the table :
> >       coord1  |     coord2    |  coord3       |  coord4      |  pol
> >  geom_data | geom_data | geom_data | geom_data |  I WANT THIS
> >I tried with this but didnt work;
> >SELECT ST_MakePoly(ST_MakeLine(coord1, coord2, coord3, coord4, coord5, coord1 ) from table
> >the problem is that I can't make i line from more than two points ( i'm using postgis v 1.3.5 and geometry ST_MakeLine(geometry[] point_array); doesn't work)
> > I'm trying to figure out how to use
> >geometry ST_MakeLine(geometry set pointfield);
> >but how do I build a geometry set pointfield???
> >sorry...really beginner!!
2009/6/22 Paragon Corporation <lr at pcorp.us>
> >Andrea,
> > Are those individual records or columns in the table?
> > Take a look at ST_MakeLine, ST_MakePolygon, ST_BuildArea
> >postgis.refractions.net/documentation/manual-svn/ST_MakeLine.html
> >postgis.refractions.net/documentation/manual-svn/ST_BuildArea.html
> >postgis.refractions.net/documentation/manual-svn/ST_MakePolygon.html
> > You build a line from points with ST_MakeLine and then do a ST_BuildArea or
> > ST_MakePolygon depending on your desired effect.
> > Leo
> > -----Original Message-----
> > From: postgis-users-bounces at postgis.refractions.net
> > [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Caspa
> > Sent: Monday, June 22, 2009 10:15 AM
> > To: postgis-users at postgis.refractions.net
> > Subject: [postgis-users] build a polygon from points
> > Hi everybody,
> > I'm new to postgis...
> > how can i build a polygon starting from points and not from x,y coord?
> > i have a table built like this:
> > point1 | point2 | point3 | point4 | polygon
> > guess i have to use MakeLine and MakePolygon but i can't fugure out why...
> > thanks in advance
> > Andrea
> > postgis-users mailing list
> >postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090623/485cab3b/attachment.html>
