[postgis-users] build a polygon from points
Caspa caspa.andre at gmail.com
Tue Jun 23 00:49:00 PDT 2009
Yes, i saw it, but in postgis 1.3.5 geometry *ST_MakeLine*(geometry[]
point_array);  is not implemented...
gives error...
here it is
ERROR:  function makeline(geometry[]) does not exist
LINE 1: SELECT MakeLine(ARRAY[MakePoint(1,2,3),MakePoint(3,4,5), Mak...
you can check it here (just above example title)
http://postgis.refractions.net/documentation/manual-svn/ST_MakeLine.html
2009/6/23 <nicklas.aven at jordogskog.no>
>  ok
> you saw my second answer?
> st_makeline should work if you just define an apoint array like
> array[point1, point2,point2, point1]
> /Nicklas
> 2009-06-23 Caspa wrote:
> yeah this could be the solution...unfortunately I have postgis version
> 1.3.5 and i doesn't have this feature yet..(I'm on debian system and don't
> want to build from source)
> >>SELECT ST_MakePoly(ST_>
> >LineFromMultiPoint(ST_collect(coord1, coord2, coord3, coord4, coord5,
> coord1 ))) from table
> >this doesn't work, but I'm trying to use LineFromMultiPoint in other
> ways...maybe it works...
> >THANKS
> >SELECT ST_MakePoly(ST_> LineFromMultiPoint(ST_collect(coord1, coord2,
> coord3, coord4, coord5, coord1 ))) from table
> > > > About st_makeline an array is needed like this example:
> > select st_makepolygon(ST_MakeLine(array[st_point(3, 2),st_point(2,
> 2),st_point(3, 3),st_point(2, 5),st_point(5, 5),st_point(3, 2)]));
> > greetings
> > Nicklas> >
> > Hi, thanks for that,
> > >those are colunm in the table :
> > >       coord1  |     coord2    |  coord3       |  coord4      |  pol
> > >  geom_data | geom_data | geom_data | geom_data |  I WANT THIS
> > >I tried with this but didnt work;
> > >SELECT ST_MakePoly(ST_MakeLine(coord1, coord2, coord3, coord4, coord5,
> coord1 ) from table
> > >the problem is that I can't make i line from more than two points ( i'm
> using postgis v 1.3.5 and geometry *ST_MakeLine*(geometry[] point_array);
> doesn't work)
> > > I'm trying to figure out how to use
> > >geometry *ST_MakeLine*(geometry set pointfield);
> > >but how do I build a geometry set pointfield???
> > >sorry...really beginner!!
> > > 2009/6/22 Paragon Corporation <lr at pcorp.us>
> > >Andrea,
> > > Are those individual records or columns in the table?
> > > Take a look at ST_MakeLine, ST_MakePolygon, ST_BuildArea
> > >postgis.refractions.net/documentation/manual-svn/ST_BuildArea.html
> > >postgis.refractions.net/documentation/manual-svn/ST_MakePolygon.html
> > > You build a line from points with ST_MakeLine and then do a
> ST_BuildArea or
> > > ST_MakePolygon depending on your desired effect.
> > > Leo
> > > -----Original Message-----
> > > From: postgis-users-bounces at postgis.refractions.net
> > > [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> Caspa
> > > Sent: Monday, June 22, 2009 10:15 AM
> > > To: postgis-users at postgis.refractions.net
> > > Subject: [postgis-users] build a polygon from points
> > > Hi everybody,
> > > I'm new to postgis...
> > > how can i build a polygon starting from points and not from x,y coord?
> > > i have a table built like this:
> > > point1 | point2 | point3 | point4 | polygon
> > > guess i have to use MakeLine and MakePolygon but i can't fugure out
> why...
> > > thanks in advance
> > > Andrea
> > > postgis-users mailing list
> > >postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090623/47d09983/attachment.html>
