[postgis-users] Points and Polygons table
Paragon Corporation
lr at pcorp.us
Thu Jun 25 13:53:34 PDT 2009
Its preferable to store them in a different table. It really depends what
you are planning to do with these. I would suggest though that since you
are new to PostGIS it would be best to stick with the standard conventions
of different geometry types/srids in different tables. You can mix them
together, but there are caveats involved if you want to ever display these
in Desktop apps or using web mapping servers/feature servers if you go down
that road.
Leo
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of tommy408
Sent: Thursday, June 25, 2009 9:39 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Points and Polygons table
I imported some points from a shapefile to a PostGIS table. But I can't
insert polygons into the same table because of the constaint below. Should
I store points in a different table from polygons or put them together in
one table and remove the following constaint?
enforce_geotype_the_geom CHECK (geometrytype(the_geom) =
'MULTIPOLYGON'::text OR the_geom IS NULL)
View this message in context:
http://www.nabble.com/Points-and-Polygons-table-tp24203451p24203451.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
