[postgis-users] St_boundary and illegal argument exception
Kevin Neufeld
kneufeld at refractions.net
Fri Jun 26 19:41:52 PDT 2009
I'm not sure exactly what you are trying to do, but yes, ST_Boundary
does extract linework (aka. the boundary) from a polygon.
SELECT ST_AsText(ST_Boundary('POLYGON((0 0, 1 1, 1 0, 0 0))'::geometry));
st_astext
LINESTRING(0 0,1 1,1 0,0 0)
(1 row)
Can you isolate the geometry that is causing you grief?
-- Kevin
George Silva wrote:
> Hello everyone.
> I'm trying to build a function that will transforma one polygon into
> many lines. I have a lot table, and i would like to insert each line
> from each lot in a table, containing the id of the lot.
> I've tried: SELECT gid, St_boundary(the_geom) INTO lines from lots and
> postgis gave me an error:
> *NOTICE: IllegalArgumentException: Number of points must be 0 or >3
> ERROR: POSTGIS2GEOS conversion failed
> ********** Erro **********
> SQL state: XX000*
> I'm wondering if that is the right approach? I'm not even sure if
> boundary is what i am looking for. Can anyone help me? Why postgis
> gave me this error?
> Thanks in advanced.
> George
> George R. C. Silva
> Sigma Consultoria
> Desenvolvimento em GIS
> www.consultoriasigma.com.br <http://www.consultoriasigma.com.br>
> www.sigmaconsultoria.blogspot.com
> <http://www.sigmaconsultoria.blogspot.com>
> postgis-users mailing list
