[postgis-users] Postgresql JDBC Driver source download problem
Chris Hermansen chris.hermansen at timberline.ca
Tue Jun 30 18:48:37 PDT 2009
Hi Jenny;
The source code downloadable from the page you mention is not a zip file.
http://jdbc.postgresql.org/download/postgresql-jdbc-8.3-604.src.tar.gz
is a gzipped tar file.  You need gnu tar or any old tar and gunzip to
get this back into a source tree.  You may need other gnu tools to build
it, I don't know.
It may be the case that the easiest way to build it on Windows is to
first install cygwin - available from http://www.cygwin.com/ - which
will give you gnu tar, or alternatively you may wish to avail yourself
of a Linux machine if you have one handy.
If you just want to use it, you don't need to build it first; just get
the appropriate jar file for your JVM and PostgreSQL version.
"Jenny" Guilian Wang wrote:
> Hi,
> From http://jdbc.postgresql.org/download.html, I tried to download
> JDBC source, no source zip of the supported versions can be opened by
> WinZip, and WinZip complains 'Error reading header after processing 0
> entries".
> Did anyone meet the same problem? Could you please let me know how you
> resolved it or share with me a valid source zip of any version 8.1,
> 8.2 or 8.3 ?
> Appreciate your help very much!
> Jenny
> postgis-users mailing list
Regards,
Chris Hermansen         mailto:chris.hermansen at timberline.ca
tel+1.604.714.2878 · fax+1.604.733.0631 · mob+1.778.232.0644
Timberline Natural Resource Group · http://www.timberline.ca
401 · 958 West 8th Avenue  · Vancouver BC · Canada · V5Z 1E5
