[postgis-users] I can't see the geometry column by console
Eduin Yezid Carrillo Vega
yecarrillo at gmail.com
Tue Mar 3 09:45:09 PST 2009
Do a
SELECT ST_as EWKT(the_geom)
instead of
SELECT the_geom
to show the geometry in text form.
Eduin Yesid Carrillo Vega
Ingeniero Civil, Esp. Sistemas de Información Geográfica
Centro de Investigación y Desarrollo en Información Geográfica
Instituto Geográfico Agustín Codazzi - IGAC
Cr 30 48-51
Tel +57 1 3694000 ext 4593
Bogotá D.C., Colombia
On Tue, Mar 3, 2009 at 12:37 PM, Paul Ramsey <pramsey at opengeo.org> wrote:
> The problem is the console is probably choking on large strings
> (geometries in text form can get pretty darn large). It really should
> not matter to you, I hope. You've confirmed the data is in the
> database with other means, so now you can go ahead and do things with
> it.
> Yours,
> P.
> On Tue, Mar 3, 2009 at 9:24 AM, marta vicente romero
> <mviceromgvsig at gmail.com> wrote:
>> Hello
>> I have a table with geographics dates
>> I can't see the geometry column in the console
>> however with a GIS or pgadmin it shows correctly ..
>> what is the problem?
>> with linux it shows, but I need work with windows
>> I do an text file whith pg_dump ..
>> when I put this file in de BD by windows, it fails.
>> (sorry I don't speak English very well)
>> thanks you very much
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
