[postgis-users] PostGIS view in qgis
Randall, Eric
ERandall at eriecountygov.org
Mon Mar 9 08:58:20 PDT 2009
Try OpenJump with the dbquery plugin. You don't even need the view.
-Eric
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net]On Behalf Of Martin Fafard
Sent: Monday, March 09, 2009 11:11 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] PostGIS view in qgis
Eduin
Thank you for the answer but it doesn't work. Since I create new objects from a view (polygonize), it seem to be impossible to create a unique id in this view for these objects. Someone else have ever aggregate geom in a view to see it in qgis or other viewer??
Martin F
Eduin Yezid Carrillo Vega a écrit :
If your postgresql version is 8.0 or less you can use OID fields as
key identifier.
CREATE VIEW myview AS SELECT oid AS gid, the_geom FROM mytable;
In postgresql 8.3 you can force oid creation if WITH OIDS is specified
when the table is created
Eduin Yesid Carrillo Vega
Ingeniero Civil, Esp. Sistemas de Información Geográfica
Centro de Investigación y Desarrollo en Información Geográfica
Instituto Geográfico Agustín Codazzi - IGAC
Cr 30 48-51
Tel +57 1 3694000 ext 4593
Bogotá D.C., Colombia
On Mon, Mar 9, 2009 at 2:43 AM, Marc Jansen <mailto:jansen.marc at gmx.de> <jansen.marc at gmx.de> wrote:
HI Martin,
Martin Fafard schrieb:
Hi
I polygonize linestrings in a view to see the result in qgis. But qgis
need gid. How can I create the gid column after an aggregate function in a
view?
AFAIK you can't. Maybe a table (created by your query) with a serial /
primary key helps.
--Marc
Martin F
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
_____
No virus found in this incoming message.
Checked by AVG - www.avg.com
Version: 8.0.237 / Virus Database: 270.11.9/1990 - Release Date: 03/08/09 17:17:00
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090309/a09c832d/attachment.html>
