[postgis-users] pb OpenLayers using a local Mapserver
Barend Kobben
kobben at itc.nl
Mon Mar 9 09:36:02 PDT 2009
Yes, this is (part of) a valid getCapabilities. Further down there should be
a section that describes the LAYERs, with for each layer at least a TITLE
and a valid BBOX (= bounding box). Check if this bounding box is there and
is corresponding with the actual data you have. If not, there is an error
somewhere, most likely in the set up of your SRS (= spatial reference system
= the projection of your map and your data), or the EXTENT (the part of the
world you define your data to depict)....
Barend
On 09-03-09 16:10, "Quentin Page" <Quentin.Page at ensg.eu> wrote:
> yes I tried
> http://localhost/cgi-bin/mapserv.exe?map=ms4w/apache/htdon
> cs/projet2009/ICPE.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetCapabilities
> and I received a file mapserver.exe what I rename "mapserver.xml" this
> file wasn't empty.
> the message is for sevreal lines
> <DescribeLayer>
> <Format>text/xml</Format>
> <DCPType>
> <HTTP>
> <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"
> xlink:href="http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apache/htdocs/proje
> t2009/ICPE.map&"/></Get>
> <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"
> t2009/ICPE.map&"/></Post>
> </HTTP>
> </DCPType>
> </DescribeLayer>
> <GetLegendGraphic>
> <Format>image/gif</Format>
> <Format>image/png</Format>
> <Format>image/png; mode=24bit</Format>
> <Format>image/jpeg</Format>
> <Format>image/wbmp</Format>
> <DCPType>
> <HTTP>
> </HTTP>
> </DCPType>
> </GetLegendGraphic>
> but i don't see the data
> OK, but did you try to get it working by just typing the URL in a browser?
>> That tests the actual Mapserver request, to see if that part of the setup
>> works...
>> Something like:
>> http://localhost/cgi-bin/mapserv?map=/projet2009/ICPE.map&SERVICE=WMS&VERSIO
>> N=1.1.1&REQUEST=GetCapabilities should result in a GetCapabilities XML
>> being
>> sent to you.
>> Barend
>> On 09-03-09 08:41, "Quentin Page" <Quentin.Page at ensg.eu> wrote:
>>> thanks for your reponce
>>> but i have the same probleme the data doesnt viewed.
>>> quentin page
>>> ecole des sciences géographique
>>> france
>>>> did you try this 'just'on mapserver, ie. without OpenLayers...? To me
>>>> the
>>>> URL to mapserver just seems to be wrong , I suspect that i.s.o.
>>>> 'http://localhost/cgi-bin/mapserv?/projet2009/ICPE.map',
>>>> it should read
>>>> 'http://localhost/cgi-bin/mapserv?map=/projet2009/ICPE.map',
>>>> Barend Köbben
>>>> International Institute for Geo-information Sciences and Earth
>>>> Observation (ITC)
>>>> PO Box 6, 7500AA Enschede (The Netherlands)
>>>> ph: +31-(0)534874253
>>>> _____
>>>> Van: postgis-users-bounces at postgis.refractions.net namens Quentin Page
>>>> Verzonden: zo 8-3-2009 21:14
>>>> Aan: postgis-users at postgis.refractions.net
>>>> Onderwerp: [postgis-users] pb OpenLayers using a local Mapserver
>>>> Hi,
>>>> i have got a problem using openlayers with a mapserver.
>>>> It seems that my use of the constructor doesnt work for any reason.
>>>> The mapfile which should be viewed has already worked (in PHP).
>>>> Could we help me please ? Is it the good way to create a openlayers ?
>>>> var map = new OpenLayers.Map('map');
>>>> var wms = new OpenLayers.Layer.WMS( "ICPE",
>>>> {layers: 'roads'},
>>>> {singleTile: true, opacity: 0.5, isBaseLayer : true}
>>>> map.addLayer(wms);
>>>> Thanks a lots !!!!!
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>>> International Institute for Geo-Information Science and Earth
>>>> Observation
>>>> (ITC)
>>>> Chamber of Commerce: 410 27 560
>>>> E-mail disclaimer
>>>> The information in this e-mail, including any attachments, is intended
>>>> for
>>>> the addressee only. If you are not the intended recipient, you are
>>>> hereby
>>>> notified that any disclosure, copying, distribution or action in
>>>> relation
>>>> to the content of this information is strictly prohibited. If you have
>>>> received this e-mail by mistake, please delete the message and any
>>>> attachment and inform the sender by return e-mail. ITC accepts no
>>>> liability for any error or omission in the message content or for
>>>> damage
>>>> of any kind that may arise as a result of e-mail transmission.
>> International Institute for Geo-Information Science and Earth Observation
>> (ITC)
>> E-mail disclaimer
>> The information in this e-mail, including any attachments, is intended for
>> the addressee only. If you are not the intended recipient, you are hereby
>> notified that any disclosure, copying, distribution or action in relation
>> liability for any error or omission in the message content or for damage
International Institute for Geo-Information Science and Earth Observation (ITC)
E-mail disclaimer
The information in this e-mail, including any attachments, is intended for the addressee only. If you are not the intended recipient, you are hereby notified that any disclosure, copying, distribution or action in relation to the content of this information is strictly prohibited. If you have received this e-mail by mistake, please delete the message and any attachment and inform the sender by return e-mail. ITC accepts no liability for any error or omission in the message content or for damage of any kind that may arise as a result of e-mail transmission.
