[postgis-users] PostGIS+FreeBSD 6.0 (AMD64) and Shared object "libpq.so.5" not found
Paul Ramsey
pramsey at opengeo.org
Mon Mar 16 14:27:15 PDT 2009
export LD_LIBRARY_PATH=${LD_LIBRARY_PATH}:/usr/local/pgsql/lib
p.
2009/3/16 Jeff Hamann <jeff.hamann at forestinformatics.com>:
> I apologize for the cross post, but I can't seem to get any traction on
> solving this problem. I'm a serious autoconf, automake, and libtool
> newbie, and I'm trying to get postgis up on a FreeBSD6.0-AMD64, and keep
> getting the following results when I gmake test in
> postgresql-8.3.5/contrib/postgis directory:
> $ gmake test
> gmake -C regress test
> gmake[1]: Entering directory
> `/usr/home/hamannj/postgresql-8.3.5/contrib/postgis/regress'
> cpp -P -traditional-cpp sql-mm-circularstring_expected.in | grep -v "^$"
> cpp -P -traditional-cpp sql-mm-compoundcurve_expected.in | grep -v "^$"
> cpp -P -traditional-cpp sql-mm-curvepoly_expected.in | grep -v "^$" >
> cpp -P -traditional-cpp sql-mm-multicurve_expected.in | grep -v "^$" >
> cpp -P -traditional-cpp sql-mm-multisurface_expected.in | grep -v "^$" >
> Creating spatial db postgis_reg
> TMPDIR is /tmp/pgis_reg_86134
> PostgreSQL 8.3.5 on x86_64-unknown-freebsd6.0, compiled by GCC gcc
> (GCC) 3.4.4 [FreeBSD] 20050518
> Postgis 1.3.5 - 2009-03-16 20:44:21
> GEOS: 3.0.3-CAPI-1.4.2
> PROJ: Rel. 4.6.1, 21 August 2008
> Running tests
> loader/Point....... failed (dumping loaded table:
> /tmp/pgis_reg_86134/dumper.err)
> loader/PointM....... failed (dumping loaded table:
> loader/PointZ....... failed (dumping loaded table:
> loader/MultiPoint....... failed (dumping loaded table:
> loader/MultiPointM....... failed (dumping loaded table:
> loader/MultiPointZ....... failed (dumping loaded table:
> loader/Arc....... failed (dumping loaded table:
> loader/ArcM....... failed (dumping loaded table:
> loader/ArcZ..... failed (dumping loaded table:
> loader/Polygon....... failed (dumping loaded table:
> loader/PolygonM....... failed (dumping loaded table:
> loader/PolygonZ....... failed (dumping loaded table:
> regress. ok
> regress_index. ok
> regress_index_nulls. ok
> lwgeom_regress. ok
> regress_lrs. ok
> removepoint. ok
> setpoint. ok
> simplify. ok
> snaptogrid. ok
> affine. ok
> wkt. ok
> measures. ok
> long_xact. ok
> ctors. ok
> sql-mm-serialize. ok
> sql-mm-circularstring. ok
> sql-mm-compoundcurve. ok
> sql-mm-curvepoly. ok
> sql-mm-general. ok
> sql-mm-multicurve. ok
> sql-mm-multisurface. ok
> geojson. ok
> regress_ogc. ok
> regress_bdpoly. ok
> regress_ogc_cover. ok
> regress_proj. ok
> kml. ok
> Run tests: 39
> Failed: 12
> gmake[1]: Leaving directory
> $ cat /tmp/pgis_reg_86134/dumper.err
> results in the following:
> /libexec/ld-elf.so.1: Shared object "libpq.so.5" not found, required by
> "pgsql2shp"
> Is this because PostgreSQL was compiled using gcc 3.4.4 (old?)? Is this
> because there's some switch that's getting set in the makefile
> incorrectly. I keep seeing threads from 2005 when I search for, "Shared
> object "libpq.so.5" not found" and AMD64, but there doesn't seem to be a
> "just include the path that that shared library in your 'path'" solution
> and my libpq.so.5 is in /usr/local/pgsql/lib and being a unix sloth, I'm
> not sure how to get the OS/Makefile to 'see' the library and I don't
> know if this would be taken care of in the ./configure process...
> Does anyone have any suggestions?
> postgis-users mailing list
