[postgis-users] equal area projection
mark balman
mark.balman at gmail.com
Tue Mar 17 06:22:06 PDT 2009
Hi Mark, thanks for your help:
At the moment I am using the following setup at work (I will install to the
latest and greatest versions when I can park my current project)
PostgeSQL 8.2.5 with
"POSTGIS="1.3.1" GEOS="3.0.0rc4-CAPI-1.3.3" PROJ="Rel. 4.5.0, 22 Oct 2006"
USE_STATS"
I have finally managed to get Mollweide into postgis and its working fine,
I just need to reproject and upload 20+ shapefiles now..
Once again, many thanks for the assistance!
ATB
Mark
On Tue, Mar 17, 2009 at 9:54 AM, Mark Cave-Ayland <
mark.cave-ayland at siriusit.co.uk> wrote:
> mark balman wrote:
> Hi all
>> I am trying to add a new equal area projection into postgis (behrmann
>> and/or Robinson). I am struggling to get this to work. From the "
>> spatialreference.org <http://spatialreference.org>" website I uploaded
>> the following into postgis:
>> INSERT into spatial_ref_sys (srid, auth_name, auth_srid, proj4text,
>> srtext) values ( 954017, 'esri', 54017, '',
>> 'PROJCS["World_Behrmann",GEOGCS["GCS_WGS_1984",DATUM["WGS_1984",SPHEROID["WGS_1984",6378137,298.257223563]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Behrmann"],PARAMETER["False_Easting",0],PARAMETER["False_Northing",0],PARAMETER["Central_Meridian",0],UNIT["Meter",1],AUTHORITY["EPSG","54017"]]');
>> After this I add some data in Behrmann projection using shp2pgsql, but
>> trying a transform query such as
>> select AsText(transform(GeomFromText('Point(-75 10)',4326),954017))
>> does not work and crashes postgis.
>> I really need to get a global equal area projection to work for my
>> project (have been using Plate Carree, but obviosly not good for performing
>> area intersects) and would be grateful for any pointers on how to do this.
>> Many thanks
>> Mark
> Hi Mark,
> The SRTEXT parameter is actually not used for PROJ.4 transformations - it's
> the proj4text field which is the important part and it appears it's blank in
> your SQL above. If you can find the equivalent PROJ.4 description, you
> should be fine.
> BTW I'm quite surprised that PROJ.4 crashes with an empty proj4text - which
> version of PostGIS are you using?
> ATB,
> Mark.
> Mark Cave-Ayland - Senior Technical Architect
> PostgreSQL - PostGIS
> Sirius Corporation plc - control through freedom
> http://www.siriusit.co.uk
> t: +44 870 608 0063
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090317/90465965/attachment.html>
