[postgis-users] Index Use Craziness
Bruce Rindahl rindahl at lrcwe.com
Wed Mar 18 08:21:40 PDT 2009
Robert
I don't know how far back your data goes but you might look at this:
http://www.postgresql.org/docs/8.2/interactive/ddl-partitioning.html
Another application similar to yours used this inherited tables idea to
partition by months and a query for rainfall 15 years ago is now the
same as within the last month.  Before it was several orders of
magnitude slower.
Bruce
Burgholzer,Robert wrote:
> I am having much trouble getting postgres to use the proper index.
> I have a table with about 20 million daily rainfall observation points,
> with between 0 and 19,000 points on any given day.  In order to speed up
> querying, I have created a GIST index on the geometry column, and an
> index on the date column.
> What I want to do is to summarize the observed rainfall in another shape
> table on any given day.  If I just want to query points by date, this
> uses the date index, and performs very quickly (see "CASE 1" below).
> When I try to introduce a geometry operator, the GIST index takes over,
> and the index on the "thisdate" column is ignored.  The weird thing is,
> I can hear it churning the heck out of my hard drive checking on all the
> points. (See "CASE 2" below).
> I even tried to sub-query the points for the given date, but the index
> did not seem to be fooled ("CASE 3").  It gave me the exact same query
> plan!!  I am unsure if I really understand the way a sub-query functions
> given this result.
> Any help would be appreciated!
> Robert
> CASE 1:
> wsp=# explain select count(*) from precip_gridded where thisdate =
> '2009-01-12';
>                               QUERY PLAN
>  Aggregate  (cost=479.43..479.44 rows=1 width=0)
>    ->  Index Scan using pg_tdix on precip_gridded  (cost=0.00..451.92
> rows=11004
>  width=0)
>          Index Cond: (thisdate = '2009-01-12 00:00:00'::timestamp
> without time zone)
> (3 rows)
> CASE 2:
> '2009-01-12' and the_geom && setsrid((select extent(the_geom) from
> proj_seggroups where gid = 448),4326);
>                               QUERY PLAN
>  Aggregate  (cost=100.23..100.24 rows=1 width=0)
>    InitPlan
>      ->  Aggregate  (cost=5.87..5.88 rows=1 width=2807)
>            ->  Index Scan using psg_giix on proj_seggroups
> (cost=0.00..5.87 rows=1 width=2807)
>                  Index Cond: (gid = 448)
>    ->  Index Scan using pg_gix on precip_gridded  (cost=0.00..94.35
> rows=1 width=0)
>          Index Cond: (the_geom && setsrid(($0)::geometry, 4326))
>          Filter: ((thisdate = '2009-01-12 00:00:00'::timestamp without
> time zone) AND (the_geom && setsrid(($0)::geometry, 4326)))
> (8 rows)
> CASE 3: Sub-query by date to try and force the use of date index
> wsp=# explain select count(a.*) from (select * from precip_gridded where
> thisdate = '2009-01-12') as a where a.the_geom && setsrid((select
> extent(the_geom) from proj_seggroups where gid = 448),4326);
>                               QUERY PLAN
>  Aggregate  (cost=100.23..100.24 rows=1 width=81)
>    InitPlan
> rows=1 width=81)
> (8 rows)
> Robert W. Burgholzer
> Surface Water Modeler
> Office of Water Supply and Planning
> Virginia Department of Environmental Quality
> rwburgholzer at deq.virginia.gov
> 804-698-4405
> Open Source Modeling Tools:
> http://sourceforge.net/projects/npsource/
> postgis-users mailing list
