[postgis-users] ST_Touches and line segment
Martin Davis
mbdavis at refractions.net
Thu Mar 19 09:28:03 PDT 2009
Kevin Neufeld wrote:
> If you have overlapping polygons then use ST_Relate with a custom
> matrix. IE. ST_Relate(g1, g2, '****1****') will return TRUE for all
> geometry pairs where the intersection of the boundaries occur on a
> line (1).
You need to know the type of the input geometries. The above pattern
will work for polygons, but not for lines. The L/L and P/L situation
require different patterns:
L/L: 1********
P/L: ***1*****
> Cheers,
> Kevin
> postgis-users mailing list
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
