[postgis-users] ST_Touches and line segment
Kevin Neufeld
kneufeld at refractions.net
Thu Mar 19 09:38:33 PDT 2009
Martin Davis wrote:
> Kevin Neufeld wrote:
>> If you have overlapping polygons then use ST_Relate with a custom
>> matrix. IE. ST_Relate(g1, g2, '****1****') will return TRUE for all
>> geometry pairs where the intersection of the boundaries occur on a
>> line (1).
> You need to know the type of the input geometries. The above pattern
> will work for polygons, but not for lines. The L/L and P/L situation
> require different patterns:
> L/L: 1********
> P/L: ***1*****
Ah, yes, of course :)
The symmetric relation is also true:
L/P: *1*******
-- Kevin
