[postgis-users] Feautures omitted from ST_Buffer operation
Roger André
randre at gmail.com
Wed Mar 25 21:09:23 PDT 2009
Hi Chris,
I don't think it's a linestring. I checked the sql load file I made, and
the table is defined in it as a MULTIPOLYGON:
SELECT AddGeometryColumn('','coastlines','the_geom','-1','MULTIPOLYGON',2);
Not really sure how else to test though.
On Wed, Mar 25, 2009 at 8:46 PM, Chris Hermansen <
chris.hermansen at timberline.ca> wrote:
> This sounds to me like you might be buffering a linestring and not a
> polygon. Is that possible? Ie are the countries represented as
> outlines (linestrings) rather than polygons?
> Roger André wrote:
> > Hi All,
> > I'm having some problems with features that are being returned from an
> > ST_Buffer operation in PostGIS. When I try to buffer the extents of
> > Papua New Guinea, a large region in the middle of its extents is
> > omitted. You can see a visual representation of this at
> http://lagerratrobe.blogspot.com/2009/03/problem-with-postgis-stbuffer.html
> > If I just select the country itself, I get back all of the features
> > that I'm expecting. In the image I've posted above, the black area
> > indicates the results of that query.
> > I am using postgresql-8.3.5, and postgis-1.3.3. My select statements
> > is as follows:
> > select name, Buffer(the_geom, .12) from coastlines where
> > iso_3_code = 'PNG';
> > I've tried this using both a free countries shapefile, as well as an
> > ESRI one, and get the same results. I'm a bit baffled, and unsure if
> > I have a problem with both data sets, or in my query, or...? If
> > someone else has had a similar problem in the past, and can shed some
> > light on it, I'd greatly appreciate it.
> > Thanks in advance,
> > Roger
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> Regards,
> Chris Hermansen mailto:chris.hermansen at timberline.ca
> tel+1.604.714.2878 · fax+1.604.733.0631 · mob+1.778.232.0644
> Timberline Natural Resource Group · http://www.timberline.ca
> 401 · 958 West 8th Avenue · Vancouver BC · Canada · V5Z 1E5
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090325/6dc3d301/attachment.html>
