[postgis-users] Feautures omitted from ST_Buffer operation
Chris Hermansen
chris.hermansen at timberline.ca
Wed Mar 25 20:46:08 PDT 2009
This sounds to me like you might be buffering a linestring and not a
polygon. Is that possible? Ie are the countries represented as
outlines (linestrings) rather than polygons?
Roger André wrote:
> Hi All,
> I'm having some problems with features that are being returned from an
> ST_Buffer operation in PostGIS. When I try to buffer the extents of
> Papua New Guinea, a large region in the middle of its extents is
> omitted. You can see a visual representation of this at
> http://lagerratrobe.blogspot.com/2009/03/problem-with-postgis-stbuffer.html
> If I just select the country itself, I get back all of the features
> that I'm expecting. In the image I've posted above, the black area
> indicates the results of that query.
> I am using postgresql-8.3.5, and postgis-1.3.3. My select statements
> is as follows:
> select name, Buffer(the_geom, .12) from coastlines where
> iso_3_code = 'PNG';
> I've tried this using both a free countries shapefile, as well as an
> ESRI one, and get the same results. I'm a bit baffled, and unsure if
> I have a problem with both data sets, or in my query, or...? If
> someone else has had a similar problem in the past, and can shed some
> light on it, I'd greatly appreciate it.
> Thanks in advance,
> Roger
> postgis-users mailing list
Regards,
Chris Hermansen mailto:chris.hermansen at timberline.ca
tel+1.604.714.2878 · fax+1.604.733.0631 · mob+1.778.232.0644
Timberline Natural Resource Group · http://www.timberline.ca
401 · 958 West 8th Avenue · Vancouver BC · Canada · V5Z 1E5
