[postgis-users] Feautures omitted from ST_Buffer operation
Roger André
randre at gmail.com
Thu Mar 26 11:20:50 PDT 2009
Thanks for filing the bug. It's definitely something bad, I did a test
where I buffered every country in the world and then underlaid the original
shapefile in solid red. There are alot of random places showing though.
The explode, buffer, union and re-assemble process seems to give correct
results though.
Thanks again for the follow-up.
On Thu, Mar 26, 2009 at 11:02 AM, Martin Davis <mbdavis at refractions.net>wrote:
> Thanks for that. Nice test case! FWIW, this runs fine in JTS. Hopefully
> someone on the GEOS side can take a look at this.
> Roger André wrote:
>> Ok, here is the WKB. Let me know if there are any problems with the file.
>> On Thu, Mar 26, 2009 at 8:57 AM, Martin Davis <mbdavis at refractions.net<mailto:
>> mbdavis at refractions.net>> wrote:
>> I don't think this can be the problem - a buffer of a linestring
>> should still produce a polygon.
>> This is probably a bug in the GEOS buffer algorithm. It would
>> help if you posted the WKB or WKB for the geometry.
>> Chris Hermansen wrote:
>> This sounds to me like you might be buffering a linestring and
>> not a
>> polygon. Is that possible? Ie are the countries represented as
>> outlines (linestrings) rather than polygons?
>> Roger André wrote:
>> Hi All,
>> I'm having some problems with features that are being
>> returned from an
>> ST_Buffer operation in PostGIS. When I try to buffer the
>> extents of
>> Papua New Guinea, a large region in the middle of its
>> extents is
>> omitted. You can see a visual representation of this at
>> http://lagerratrobe.blogspot.com/2009/03/problem-with-postgis-stbuffer.html
>> If I just select the country itself, I get back all of the
>> features
>> that I'm expecting. In the image I've posted above, the
>> black area
>> indicates the results of that query.
>> I am using postgresql-8.3.5, and postgis-1.3.3. My select
>> statements
>> is as follows:
>> select name, Buffer(the_geom, .12) from coastlines where
>> iso_3_code = 'PNG';
>> I've tried this using both a free countries shapefile, as
>> well as an
>> ESRI one, and get the same results. I'm a bit baffled,
>> and unsure if
>> I have a problem with both data sets, or in my query,
>> or...? If
>> someone else has had a similar problem in the past, and
>> can shed some
>> light on it, I'd greatly appreciate it.
>> Thanks in advance,
>> Roger
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> <mailto:postgis-users at postgis.refractions.net>
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> -- Martin Davis
>> Senior Technical Architect
>> Refractions Research, Inc.
>> (250) 383-3022
> Martin Davis
> (250) 383-3022
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090326/edde16bc/attachment.html>
