[postgis-users] Problem updating a column when two polygons match
Jorge Arévalo jorge.arevalo at gmail.com
Fri Mar 27 01:10:10 PDT 2009
Hello everybody,
I have 2 tables:
T1: 8 columns. 1 geometry column of type polygon. UTM coords. Thousands
of rows
T2: 4 columns. 1 geometry column of type multipolygon. UTM coords. 29
rows. Each multipolygon has thousands of polygons.
I need to add a new column to T1. The new column's value will be taken
from one of the T2's fields (the 4th one). For each row of T1, I have to
find the multipolygon of T2 that contains the polygon of T1. When
matchs, I have to update the new T1's column with the value of 4th
column of the T2 matching row.
I'm trying something like this:
UPDATE T1 SET new_column = (SELECT T2.fourth_column from T1 JOIN T2
ON ST_DWithin(T1.polygon, T2.multipolygon, 0.0))
Yes, I know that I can use ST_Within(T1.polygon, T2.multipolygon)), but
I would need PostGIS with GEO support, and I can't compile it again.
Anyway, my big problem is that the query takes really LONG time. More
than 1 hour. And I have to translate this test to a bigger enviroment
(bigger tables). I' ve created index on the geometry columns in both
tables, but doesn't seem to be enough...
Any clues?
Thanks in advance
Jorge
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090327/568d9f66/attachment.html>
