[postgis-users] Distance between an edge and a point
Paul Ramsey
pramsey at opengeo.org
Sun May 3 13:26:09 PDT 2009
ST_Distance() will do the trick just fine. If your data is in
geographics, then the ST_Distance_Sphere() below will work instead.
P
On Sun, May 3, 2009 at 10:57 AM, Stephen Woodbridge
<woodbri at swoodbridge.com> wrote:
> Supunmali Ahangama wrote:
>> I need to find the distance (perpendicular distance) between an edge and a
>> point. Please suggest me a function in PostGIS. Can I use distance
>> function?
> select ST_distance_sphere(ST_line_interpolate_point(linestring,
> ST_line_locate_point(LineString, Point), Point);
> where you have to supply linstring and Point in the above.
> -Steve W
> postgis-users mailing list
