[postgis-users] Getting a NOTICE into a query output
Paragon Corporation lr at pcorp.us
Mon May 4 19:34:45 PDT 2009
Ben,
There is a function available in PostGIS 1.4 called ST_IsValidReason() which
does what you want.  Its in trunk and requires GEOS 3.1.0.  Unfortunately
this does not exist in PostGIS 1.3 and also requires GEOS 3.1 and above.
Hope that helps,
Regin
  _____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Ben
Madin
Sent: Monday, May 04, 2009 10:03 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Getting a NOTICE into a query output
G'day all,
I have some bad geometries (Self-intersections) that I need to fix:
when I run :
australia=# select gid, tailtag, area_name, st_astext(st_centroid(the_geom))
as centroid from tailtagarea where st_isValid(the_geom) is false order by
st_centroid(the_geom);;
 to make myself a nice list to work with I get :
NOTICE:  Self-intersection at or near point 146.646 -41.1121
NOTICE:  Self-intersection at or near point 147.787 -42.288
NOTICE:  Self-intersection at or near point 115.999 -32.7807
NOTICE:  Self-intersection at or near point 136.002 -33.3412
NOTICE:  Self-intersection at or near point 151.385 -27.7379
NOTICE:  Self-intersection at or near point 142.163 -26.2079
NOTICE:  Self-intersection at or near point 130.528 -12.7086
NOTICE:  Self-intersection at or near point 115.556 -21.4113
NOTICE:  Self-intersection at or near point 113.653 -24.8917
NOTICE:  Self-intersection at or near point 115.142 -30.6844
then :
 gid | tailtag |    area_name    |                 centroid
 276 | WCN     | Carnarvon       | POINT(114.382000002796 -24.3219058101861)
 291 | WDN     | Dandaragan      | POINT(115.504407697781 -30.5410130360183)
 380 | WWA     | Waroona         | POINT(115.91620760142 -32.8588263644047)
 343 | WMY     | Murray          | POINT(115.966965752586 -32.6237045619179)
 362 | WRO     | Roebourne       | POINT(117.03170469097 -21.0526004441269)
  60 | TDG     | Darwin And Gulf | POINT(133.897365573887 -14.2140172548334)
 247 | S71     | S71             | POINT(136.913166015303 -32.9332738397356)
  70 | QBC     | Barcoo          | POINT(142.269579925576 -25.1377197205728)
 170 | QQP     | Quilpie         | POINT(143.889867295296 -26.354593975264)
 498 | MLA     | Latrobe         | POINT(146.544098538635 -41.2417387155427)
 510 | MRS     | Ross            | POINT(147.556140609695 -42.1118612308958)
 147 | QMM     | Millmerran      | POINT(151.11832129932 -27.8551116855016)
 169 | QPW     | Pittsworth      | POINT(151.538916320118 -27.7014266930915)
(13 rows)
It would be excellent if I could get the Notice to display in the query
results, so I could print it out and work with it to quickly locate the
problems (in QGIS)
... so can I do that? or am I best to just copy and paste the notices
Unfortunately as I write this "Safari could not open the page
"http://postgis.refractions.net/documentation/" because the server is not
responding."
cheers
Ben
Ben Madin
REMOTE INFORMATION
t : +61 8 9192 5455
f : +61 8 9192 5535
m : 0448 887 220
Broome   WA   6725
ben at remoteinformation.com.au
Out here, it pays to know...
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090504/b518f85e/attachment.html>
