[postgis-users] value of spatial index on 300, 000, 000 point geometries
Paragon Corporation
lr at pcorp.us
Tue May 5 23:30:47 PDT 2009
Kevin,
I think you have a bogus proj install or your spatial_ref_sys table has some
sort of z mentioned.
I get
"SRID=4001;POINT(-122.689717977579 49.4265525863074 5)"
Though I only have proj 4.6.0 and 4.6.1 installs (tested on 1.3.3 and
1.4SVN) so can't be sure its not an issue with an older proj you have.
Anyway does anyone actually use Z for time? I always use M since in theory
its not out of the question that we wouldn't transform Z since it is a space
dimension.
Thanks,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Paul
Ramsey
Sent: Wednesday, May 06, 2009 2:04 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] value of spatial index on 300, 000, 000 point
geometries
Well, our versions differ, but that means nothing :)
medford=# select postgis_proj_version();
Rel. 4.6.1, 21 August 2008
(1 row)
I'm also running 1.4SVN. And I can't recall if I installed the grid shift
files.
P.
On Tue, May 5, 2009 at 10:55 PM, Kevin Neufeld <kneufeld at refractions.net>
wrote:
> :) So if proj doesn't have z transformation then ... I have a bogus
> proj install or corrupt spatial ref definition?
> postgis=# select postgis_proj_version();
> postgis_proj_version ------------------------- Rel. 4.4.9, 29 Oct
> 2004
> (1 row)
> Since my answer is different than yours, something is amiss.
> Paul Ramsey wrote:
>> On Tue, May 5, 2009 at 9:58 PM, Kevin Neufeld
>> wrote:
>>> But (and folks can correct me if I'm wrong since the docs don't
>>> actually
>>> specify) transforms operate on *all* dimensions.
>>> postgis=# select st_asewkt(st_transform('SRID=3005;POINT(1240227
>>> 495643 5)', 4001));
>>> st_asewkt
>>> SRID=4001;POINT(-122.689717977579 49.4258574870912 533.550271589169)
>>> (1 row)
>> That's news to me and my version of PostGIS:
>> medford=# select st_asewkt(st_transform('SRID=3005;POINT(1240227
>> 495643 5)', 4001));
>> st_asewkt
>> (1 row)
>> My intuition was that reprojection would leave Z alone, since proj4
>> has no z-transform capabilities.
>> P.
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
