[postgis-users] Problem with ST_Within, Polygons and Multipolygons
Jorge Arévalo
jorge.arevalo at gmail.com
Thu May 7 14:44:51 PDT 2009
Hello,
Many thanks for your help Kevin. I can confim one thing: isvalid only
returns the first error. Just today, I realized on the big amount of errors
of my data, as you said. Indeed, I was reading the same link that you
provided me about geometry validity, and I split my multipolygon into single
polygons to check them. My conclusions are the same as yours: what a mess!
Oh, and thanks again for your response to my original question. It helped me
a lot... Maybe is it time to ask for new data, without errors? If not, how
should I "clean" my data? I tried with ST_Buffer(geom, 0.0) (I read in this
link http://www.bostongis.com/postgis_extent_expand_buffer_distance.snippetthat
is useful to repair data with self-interesections), but doesn't seem
to
work for me...
Regards
Jorge
On Thu, May 7, 2009 at 6:58 PM, Kevin Neufeld <kneufeld at refractions.net>wrote:
> Hi Jorge,
> So, I had a quick look at your data ... I'm sorry to say that you've got a
> lot of problems with your ocean polygon.
> Paul can correct me since he did the work on isvalidreason, but I think
> st_isvalid only returns the first thing it finds wrong with your input
> geometry.
> I did this and found all kinds of things:
> -- Extract the POLYGONs from the MULTI
> CREATE TABLE water_polys AS
> SELECT (ST_Dump(the_geom)).geom AS the_geom
> FROM water;
> SELECT ST_IsValidReason(the_geom)
> FROM water_polys
> WHERE NOT ST_IsValid(the_geom);
> So, looking at the individual polygons (of which only the first error is
> again reported), I found over 66 self-intersections (figure 8's and so
> forth) and several whose boundaries loop back and touch itself.
> Also, in response to your original question about why a point on your
> airport also intersects the ocean polygon: it turns out that the island in
> question is not a hole in your ocean at all ... but a second polygon on top
> of your ocean polygon. This is why your point query returns true - there
> are two surfaces (the island and the water) that intersect the point (which,
> by the way, also makes an invalid multipolygon).
> A while back I put together some isvalid/issimple geometry descriptions
> with soem pretty pictures:
> http://postgis.refractions.net/documentation/manual-svn/ch04.html#OGC_Validity
> You may want to have a look through it and clean up your dataset. The
> invalidity will most certainly result in more unexpected behaviour.
> Cheers,
> Kevin
> Jorge Arévalo wrote:
>> Hello,
>> I have additional info. When running the method "isvalid", I get this
>> warning message:
>> NOTICE: Self-intersection at or near point -2749.99 4.7955e+06
>> What is exactly a "self-intersection"? May this "self-intersection" be the
>> cause of my problem?
>> Thanks
>> Jorge
>> 2009/5/6 Jorge Arévalo <jorge.arevalo at gmail.com <mailto:
>> jorge.arevalo at gmail.com>>
>> Hi,
>> Thanks for your response Kevin. I can provide some data:
>> - Screenshot (over geoserver) of the "water" multipolygon. You can
>> see the shape of Spain and the Balearic Islands, and a hole on the
>> left (Portugal). The multipolygon is open, isn't it? -->
>> http://www.nebulared.com/tmp_geo/water_multipolygon.jpg
>> - Zoom over Menorca (one of the Balearic Islands). As you can see,
>> the point tested is inside the "airports" multipolygon, but
>> ST_Within and ST_Contains returns that the point is inside both,
>> "water" and "airports" multipolygons -->
>> http://www.nebulared.com/tmp_geo/zoom_in_water_multipolygon.jpg
>> - The "ST_AsText" data for the "airport" multipolygon -->
>> http://www.nebulared.com/tmp_geo/airports_multipolygon.txt
>> - The "ST_AsText" data for the "water" multipolygon (rar file, 2.5
>> MB of plain text...) -->
>> http://www.nebulared.com/tmp_geo/water_multipolygon.rar
>> So, how can I check the validity of my multipolygons? Do someone
>> could help me with this?
>> Now, the query. My context is the next:
>> - I have a table with polygons that I want to check (to say if they
>> are in an airport, in a forest, in water, etc). We can call this
>> table T1. I use the centroid of the polygons to check, not the
>> entire polygon.
>> - In other different table, that we'll call T2, I have all the
>> multipolygons ("water", "airports", etc). The name of the field that
>> says if the multipolygon is "water" or "airport" or anything is
>> "clutter"
>> With this code, I pretend to loop over T1, checking if the centroid
>> of its polygons are inside of one (and ONLY one) of the
>> multipolygons of T2. (Is part of a procedure)
>> BEGIN
>> FOR s IN SELECT * FROM T1 LOOP
>> select clutter from T2 where
>> ST_Within(ST_Centroid(T1.wkb_geometry), T2.wkb_geometry))
>> END LOOP;
>> RETURN;
>> END;
>> Most of the times, the select inside the loop, returns more than one
>> result ("water" and other one, normally). That's my problem
>> I have another version of the query, with Java. Again, I loop over
>> the table T1, and check the centroid of its polygons with all the
>> multipolygons (water, airports...) that are in T2. Then, my query,
>> inside the loop, is:
>> SELECT clutter FROM T2 WHERE ST_Within(?, T2.wkb_geometry)
>> The '?' is replaced with the centroid of the polygon in T1, of
>> course. Basically, is the same idea of the previous SQL code, but
>> with Java.
>> Apart from this, other problem is that ST_Within takes a long time.
>> 1 sec per query. And I have like 2 millions of polygons (queries) to
>> check...
>> My multipolygons' table (T2) has only 29 rows (small table with
>> large geometries), and I found this
>> http://postgis.refractions.net/documentation/manual-1.3/ch05.html.
>> Seems to be good for me. But using "SET enable_seqscan TO off", the
>> queries take the same time (~ 1 sec). Maybe the other approach
>> (create an additional column that "caches" the bbox, and matching
>> against this) could help me. Any ideas on how to create this bbox
>> with my huge multipolygons?
>> Thanks in advance
>> Regards
>> Jorge
>> On Wed, May 6, 2009 at 4:28 AM, Kevin Neufeld
>> ... If is useful, I tested the method "ST_isvalid" with the
>> multipolygon and returns "false". Maybe the multipolygon is
>> not closed? I loaded the data from a shapefile. Is it
>> possible to create a "non-valid" multipolygon? Does PostGIS
>> accept this?
>> Ah, yes. Most spatial predicates in PostGIS assume the input
>> geometry is valid. Suppose you had defined a POLYGON with a
>> hole or inner ring outside of the exterior ring. What is the
>> area? Does the question even make sense? PostGIS allows
>> invalid geometries in the database so users can make full use of
>> the PostGIS toolset to do whatever they need (ie. breakdown a
>> polygon to it's constituent linework and rebuild it back up
>> again to a valid polygon)
>> Ok, being even more specific. I'm working with data about
>> Spain. I have a HUGE multipolygon that represents "water"
>> (this is, the coasts around Spain and its islands). Then,
>> the "holes" inside this multypolygon have the shape of
>> Spain, Balearic Islands and Canary Islands. Of course, I
>> have more multipolygons that represent "forests",
>> "airports", "cities", etc, that fit into these holes.
>> Really, my problem is with some points that belong to an
>> airport in an island. Using "ST_Within" and "ST_Contains",
>> the result is that these points belong to the multipolygon
>> "airport" and multipolygon "water" at same time. Obviously,
>> the island (and its airport) is surrounded by water, but the
>> airport's points shouldn't be part of the multopolygon
>> "water". And, as I said, when I apply "ST_isvalid" to the
>> multipolygon "water", returns false. Maybe is not closed?
>> Yeah, as mentioned before, a point that is not on the surface of
>> a (multi)polygon (whether in a hole or completely outside) is
>> not considered within the (multi)polygon. It does sound like
>> your ocean polygon has validity issues.
>> Oh, btw, what's the difference between "ST_Within" and
>> "Within". Does "ST_Within" use index instead of geometry? Am
>> I right?
>> No, not instead of. Both use the actual geometry for testing
>> within. ST_Within will also use the index to narrow down the
>> candidate list first.
>> As you can see, the definition of ST_Within is just a simple SQL
>> wrapper that first invokes the index.
>> postgis=# select prosrc from pg_proc where proname = 'st_within';
>> prosrc
>> SELECT $1 && $2 AND _ST_Within($1,$2)
>> (1 row)
>> http://postgis.refractions.net/documentation/manual-svn/ST_Within.html
>> Cheers,
>> Kevin
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> <mailto:postgis-users at postgis.refractions.net>
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090507/3afe26f5/attachment.html>
