[postgis-users] Problem with ST_Within, Polygons and Multipolygons
Kevin Neufeld
kneufeld at refractions.net
Thu May 7 15:16:45 PDT 2009
Yeah, that's a good question. You could try to break-down your ocean geometry into the raw linework, properly node the
linework, and then rebuild your polygons.
ie.
-- Extract the linework
CREATE TABLE water_poly_boundaries AS
SELECT st_collect(st_boundary(the_geom)) AS the_geom
FROM water_polys ;
-- Node the linework
CREATE TABLE water_boundaries_noded AS
SELECT st_union(the_geom, st_startpoint(the_geom)) AS the_geom
FROM water_poly_boundaries ;
Then use buildarea or polygonize to rebuild the polygons.
-- Kevin
Jorge Arévalo wrote:
> Oh, and thanks again for your response to my original question. It
> helped me a lot... Maybe is it time to ask for new data, without errors?
> If not, how should I "clean" my data? I tried with ST_Buffer(geom, 0.0)
> (I read in this link
> http://www.bostongis.com/postgis_extent_expand_buffer_distance.snippet
> that is useful to repair data with self-interesections), but doesn't
> seem to work for me...
> Regards
> Jorge
