[postgis-users] Problem with ST_Within, Polygons and Multipolygons
Jorge Arévalo jorge.arevalo at gmail.com
Thu May 7 17:11:02 PDT 2009
Hi Kevin,
Wow, some new concepts here. Now, I'm not in front of my computer, but I'll
try these operations asap. I think that I've a couple of questions about
them, but I'll wait.
Many thanks!
Jorge
On Fri, May 8, 2009 at 12:16 AM, Kevin Neufeld <kneufeld at refractions.net>wrote:
> Yeah, that's a good question.  You could try to break-down your ocean
> geometry into the raw linework, properly node the linework, and then rebuild
> your polygons.
> ie.
> -- Extract the linework
> CREATE TABLE water_poly_boundaries AS
> SELECT st_collect(st_boundary(the_geom)) AS the_geom
> FROM water_polys ;
> -- Node the linework
> CREATE TABLE water_boundaries_noded AS
> SELECT st_union(the_geom, st_startpoint(the_geom)) AS the_geom
> FROM water_poly_boundaries ;
> Then use buildarea or polygonize to rebuild the polygons.
> -- Kevin
> Jorge Arévalo wrote:
>> Oh, and thanks again for your response to my original question. It helped
>> me a lot... Maybe is it time to ask for new data, without errors? If not,
>> how should I "clean" my data? I tried with ST_Buffer(geom, 0.0) (I read in
>> this link
>> http://www.bostongis.com/postgis_extent_expand_buffer_distance.snippetthat is useful to repair data with self-interesections), but doesn't seem to
>> work for me...
>> Regards
>> Jorge
>>  _______________________________________________
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090508/816cb5be/attachment.html>
