[postgis-users] Problem with ST_Within, Polygons and Multipolygons
Jorge Arévalo jorge.arevalo at gmail.com
Thu May 7 16:42:46 PDT 2009
Hi Brent,
Thanks for the tip. Apart from the use of buffer(buffer(geom, -1),1) instead
of buffer(geom, 0), that was my first approach to the solution. But after
fixing 3-4 polygons, I thought that it should be an automatic process to do
this. My geometries have thousands of polygons, and this method may take a
long time. Anyway, I'll test the use of buffer. If fixes the most of my
bad-constructed polygons, should be the best solution.
Many thanks!
On Fri, May 8, 2009 at 12:39 AM, <pcreso at pcreso.com> wrote:
> HIi
> I have tried a few ways of dealing with this, including
> ST_Simplify_PreserveTopology() to try to fix errors.
> I have yet to find a solution that automatically resolves such probles as I
> think they should be. Using some variation of buffer(buffer(geom,-1),1)
> instead of buffer(geom,0) sometimes fixes things that the simple buffer of
> zero has failed to.
> What I have done that works for me is to use QGIS to edit the geometries
> that are not fixed by the above operations.
> I run isvalid() limit 1, then zoom into the returned coodinates & manually
> fix the problems, which so far have always been pretty simple & obvious. I
> then rerun isvalid() & work through each error, It doesn't take long per
> error, 200 or so can be fixed in a morning without too much trouble.
> Also note that an empty geometry is regarded as an error by some
> applications, but passes isvalid(), so I also do a check for
> ST_NumGeomteries()=0 to clean up PostGIS datasets.
> HTH,
>   Brent Wood
> --- On Fri, 5/8/09, Jorge Arévalo <jorge.arevalo at gmail.com> wrote:
> > From: Jorge Arévalo <jorge.arevalo at gmail.com>
> > Subject: Re: [postgis-users] Problem with ST_Within, Polygons and
>  Multipolygons
> > To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
> > Date: Friday, May 8, 2009, 9:44 AM
> > Hello,
> > Many thanks for your help Kevin. I can confim one thing:
> > isvalid only returns the first error. Just today, I realized
> > on the big amount of errors of my data, as you said. Indeed,
> > I was reading the same link that you provided me about
> > geometry validity, and I split my multipolygon into single
> > polygons to check them. My conclusions are the same as
> > yours: what a mess!
> > Oh, and thanks again for your response to my original
> > question. It helped me a lot... Maybe is it time to ask for
> > new data, without errors? If not, how should I
> > "clean" my data? I tried with ST_Buffer(geom, 0.0)
> > (I read in this link
> http://www.bostongis.com/postgis_extent_expand_buffer_distance.snippet
> > that is useful to repair data with self-interesections), but
> > doesn't seem to work for me...
> > Regards
> > Jorge
> > On Thu, May 7, 2009 at 6:58 PM,
> > Kevin Neufeld <kneufeld at refractions.net>
> > wrote:
> > Hi Jorge,
> > So, I had a quick look at your data ... I'm sorry to
> > say that you've got a lot of problems with your ocean
> > polygon.
> > Paul can correct me since he did the work on isvalidreason,
> > but I think st_isvalid only returns the first thing it finds
> > wrong with your input geometry.
> > I did this and found all kinds of things:
> > -- Extract the POLYGONs from the MULTI
> > CREATE TABLE water_polys AS
> > SELECT (ST_Dump(the_geom)).geom AS the_geom
> > FROM water;
> > SELECT ST_IsValidReason(the_geom)
> > FROM water_polys
> > WHERE NOT ST_IsValid(the_geom);
> > So, looking at the individual polygons (of which only the
> > first error is again reported), I found over 66
> > self-intersections (figure 8's and so forth) and several
> > whose boundaries loop back and touch itself.
> > Also, in response to your original question about why a
> > point on your airport also intersects the ocean polygon: it
> > turns out that the island in question is not a hole in your
> > ocean at all ... but a second polygon on top of your ocean
> > polygon.  This is why your point query returns true - there
> > are two surfaces (the island and the water) that intersect
> > the point (which, by the way, also makes an invalid
> > multipolygon).
> > A while back I put together some isvalid/issimple geometry
> > descriptions with soem pretty pictures:
> http://postgis.refractions.net/documentation/manual-svn/ch04.html#OGC_Validity
> > You may want to have a look through it and clean up your
> > dataset.  The invalidity will most certainly result in more
> > unexpected behaviour.
> > Cheers,
> > Kevin
> > Jorge Arévalo wrote:
> > Hello,
> > I have additional info. When running the method
> > "isvalid", I get this warning message:
> > NOTICE:  Self-intersection at or near point -2749.99
> > 4.7955e+06
> > What is exactly a "self-intersection"? May this
> > "self-intersection" be the cause of my problem?
> > Thanks
> > Jorge
> > 2009/5/6 Jorge Arévalo <jorge.arevalo at gmail.com
> > <mailto:jorge.arevalo at gmail.com>>
> >     Hi,
> >     Thanks for your response Kevin. I can provide some
> > data:
> >     - Screenshot (over geoserver) of the
> > "water" multipolygon. You can
> >     see the shape of Spain and the Balearic Islands, and
> > a hole on the
> >     left (Portugal). The multipolygon is open, isn't
> > it? -->
> >     http://www.nebulared.com/tmp_geo/water_multipolygon.jpg
> >     - Zoom over Menorca (one of the Balearic Islands). As
> > you can see,
> >     the point tested is inside the "airports"
> > multipolygon, but
> >     ST_Within and ST_Contains returns that the point is
> > inside both,
> >     "water" and "airports"
> > multipolygons -->
> >     http://www.nebulared.com/tmp_geo/zoom_in_water_multipolygon.jpg
> >     - The "ST_AsText" data for the
> > "airport" multipolygon -->
> >     http://www.nebulared.com/tmp_geo/airports_multipolygon.txt
> > "water" multipolygon (rar file, 2.5
> >     MB of plain text...) -->
> >     http://www.nebulared.com/tmp_geo/water_multipolygon.rar
> >     So, how can I check the validity of my multipolygons?
> > Do someone
> >     could help me with this?
> >     Now, the query. My context is the next:
> >     - I have a table with polygons that I want to check
> > (to say if they
> >     are in an airport, in a forest, in water, etc). We
> > can call this
> >     table T1. I use the centroid of the polygons to
> > check, not the
> >     entire polygon.
> >     - In other different table, that we'll call T2, I
> > have all the
> >     multipolygons ("water",
> > "airports", etc). The name of the field that
> >     says if the multipolygon is "water" or
> > "airport" or anything is
> >     "clutter"
> >     With this code, I pretend to loop over T1, checking
> > if the centroid
> >     of its polygons are inside of one (and ONLY one) of
> > the
> >     multipolygons of T2.  (Is part of a procedure)
> >     BEGIN
> >       FOR s IN SELECT * FROM T1 LOOP
> >             select clutter from T2 where
> >     ST_Within(ST_Centroid(T1.wkb_geometry),
> > T2.wkb_geometry))
> >       END LOOP;
> >       RETURN;
> >     END;
> >     Most of the times, the select inside the loop,
> > returns more than one
> >     result ("water" and other one, normally).
> > That's my problem
> >     I have another version of the query, with Java.
> > Again, I loop over
> >     the table T1, and check the centroid of its polygons
> > with all the
> >     multipolygons (water, airports...) that are in T2.
> > Then, my query,
> >     inside the loop, is:
> >     SELECT clutter FROM T2 WHERE ST_Within(?,
> > T2.wkb_geometry)
> >     The '?' is replaced with the centroid of the
> > polygon in T1, of
> >     course. Basically, is the same idea of the previous
> > SQL code, but
> >     with Java.
> >     Apart from this, other problem is that ST_Within
> > takes a long time.
> >     1 sec per query. And I have like 2 millions of
> > polygons (queries) to
> >     check...
> >     My multipolygons' table (T2) has only 29 rows
> > (small table with
> >     large geometries), and I found this
> >     http://postgis.refractions.net/documentation/manual-1.3/ch05.html.
> >     Seems to be good for me. But using "SET
> > enable_seqscan TO off", the
> >     queries take the same time (~ 1 sec). Maybe the other
> > approach
> >     (create an additional column that "caches"
> > the bbox, and matching
> >     against this) could help me. Any ideas on how to
> > create this bbox
> >     with my huge multipolygons?
> >     Thanks in advance
> >     Regards
> >     Jorge
> >     On Wed, May 6, 2009 at 4:28 AM, Kevin Neufeld
> > <mailto:kneufeld at refractions.net>>
> >             ... If is useful, I tested the method
> > "ST_isvalid" with the
> >             multipolygon and returns
> > "false". Maybe the multipolygon is
> >             not closed? I loaded the data from a
> > shapefile. Is it
> >             possible to create a
> > "non-valid" multipolygon? Does PostGIS
> >             accept this?
> >         Ah, yes.  Most spatial predicates in PostGIS
> > assume the input
> >         geometry is valid.  Suppose you had defined a
> > POLYGON with a
> >         hole or inner ring outside of the exterior
> > ring.  What is the
> >         area?  Does the question even make sense?
> >  PostGIS allows
> >         invalid geometries in the database so users can
> > make full use of
> >         the PostGIS toolset to do whatever they need
> > (ie. breakdown a
> >         polygon to it's constituent linework and
> > rebuild it back up
> >         again to a valid polygon)
> >             Ok, being even more specific. I'm
> > working with data about
> >             Spain. I have a HUGE multipolygon that
> > represents "water"
> >             (this is, the coasts around Spain and its
> > islands). Then,
> >             the "holes" inside this
> > multypolygon have the shape of
> >             Spain, Balearic Islands and Canary
> > Islands. Of course, I
> >             have more multipolygons that represent
> > "forests",
> >             "airports", "cities",
> > etc, that fit into these holes.
> >             Really, my problem is with some points
> > that belong to an
> >             airport in an island. Using
> > "ST_Within" and "ST_Contains",
> >             the result is that these points belong to
> > the multipolygon
> >             "airport" and multipolygon
> > "water" at same time. Obviously,
> >             the island (and its airport) is
> > surrounded by water, but the
> >             airport's points shouldn't be
> > part of the multopolygon
> >             "water". And, as I said, when I
> > apply "ST_isvalid" to the
> >             multipolygon "water", returns
> > false. Maybe is not closed?
> >         Yeah, as mentioned before, a point that is not
> > on the surface of
> >         a (multi)polygon (whether in a hole or
> > completely outside) is
> >         not considered within the (multi)polygon.  It
> > does sound like
> >         your ocean polygon has validity issues.
> >             Oh, btw, what's the difference
> > between "ST_Within" and
> >             "Within". Does
> > "ST_Within" use index instead of geometry? Am
> >             I right?
> >         No, not instead of.  Both use the actual
> > geometry for testing
> >         within.  ST_Within will also use the index to
> > narrow down the
> >         candidate list first.
> >         As you can see, the definition of ST_Within is
> > just a simple SQL
> >         wrapper that first invokes the index.
> >         postgis=# select prosrc from pg_proc where
> > proname = 'st_within';
> >                       prosrc
> >         SELECT $1 && $2 AND _ST_Within($1,$2)
> >         (1 row)
> http://postgis.refractions.net/documentation/manual-svn/ST_Within.html
> >         Cheers,
> >         Kevin
> >  _______________________________________________
> >         postgis-users mailing list
> >         <mailto:postgis-users at postgis.refractions.net>
> >         http://postgis.refractions.net/mailman/listinfo/postgis-users
> > -----Inline Attachment Follows-----
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090508/7878bb19/attachment.html>
